Stock Boost Pressure
Old May 2, 2005 | 07:03 PM
deegan42's Avatar
Question Stock Boost Pressure
what is the stock boost pressure on a 2002 wrx. When i had my boost gauge installed a year ago i was reading peak at 10 psi. Then i got a boost controller and put it up to 11 thinking it was 1 pound over. Now i have people telling me that stock boost is 14 pounds. Does this mean there is a problem with my car? I think that the person that installed my gauge did not tap into the line next to the bov he did it somewhere else. Would this make a difference? It is a cheap gauge and the only mod i had was a ram intake.
Old May 2, 2005 | 08:52 PM
deegan42's Avatar
i know that stock boost is 13.8 psi the question was really about why my meter is reading 10psi. Anyone else ever have problems like this?
Old May 2, 2005 | 10:46 PM
aaron222's Avatar
I think stock psi is 14.5
Old May 2, 2005 | 10:55 PM
RU-X's Avatar
Car Info: 05 wrx
i think 14.5 is for the STI for the wrx its 13.5.... or it is for mine anways
Old May 3, 2005 | 09:29 AM
meilers's Avatar
Stock boost for the WRX is 13.8, but boost varies according to what gear you are in. I can only hit 12.5 or 13.1 PSI in 1st and 2nd, but in 3rd I hit 13.8 and 14.1 for 4rth and 5th. I've got a digital gauge with peak hold, which is how I can take accurate readings without crashing.
If your boost gauge was reading incorrectly (which it may not be -- you might have a more serious problem) then it is simply broken or you have a leak somewhere in the line that has been tapped. There is no way for one part of the system to be at 10psi while other parts are at 14psi; pressure is equalized throughout the system unless you are tapped into a vacuum line.
Old May 3, 2005 | 09:53 AM
deegan42's Avatar
thanks for the help meilers. i am going to get this sorted out imediatly.
Old May 9, 2005 | 11:32 PM
meilers's Avatar
Well, I told you that boost for the stock WRX is 13.8 PSI.
HOWEVER, I just got an accurate boost gauge, and I found out that I am boosting to 14.4 PSI...
...in second gear!
This is with a totally stock 02 WRX; only "mod" is a Perrin foam air filter. I thought boost was locked at 12psi in 1st and 2nd, but that doesn't seem to be the case in my situation! This is measured using an ECU monitor, so I am readin the car's own boost sensor, not a 3rd-party gauge...
14.4 PSI on a stock TD-04; does that seem risky to anyone here?
Old May 10, 2005 | 08:21 PM
st0ckwRx03's Avatar
Car Info: WRX 03
i'm running 14.5psi on all of my gears when i floor it and my car is all stock ....but because maybe i have an 03
Old May 12, 2005 | 07:23 PM
SubyWRXdude's Avatar
it also depends what elevation you're at too, because here in colorado, we dont actually get the stock rated boost, sucks!
Old May 13, 2005 | 12:04 AM
hayakunai's Avatar
the dealership people say it 13.1 psi
Old May 13, 2005 | 02:15 PM
meilers's Avatar
Considering I just hit 14.8 yesterday in 3rd gear, I'd say 13.1 for a stock EJ20 is not the correct number
Old May 13, 2005 | 02:21 PM
EricDaRed81's Avatar
Dirty Redhead
From: Commuting? I don't know what that means anymore.
Car Info: 05 WRX Wagon (Crystal Gray)
Stock is 13.5 on a WRX and 14.5 on a STI.
Old May 14, 2005 | 01:08 AM
hayakunai's Avatar
is every car different??
Old May 14, 2005 | 07:58 AM
meilers's Avatar
See, that information is useless with out specifying what gear and under what conditions.
My 2002 WRX, totally stock except for a Perrin panel filter and synthetic oil:
Gear 1: 13.6 PSI
Gear 2: 13.8-14.1 PSI (one freak boost to 14.4, couldn't reproduce)
Gear 3: 14.1-14.8 PSI (range in 3 runs)
Gear 4: 14.4-14.8 PSI (same)
Gear 5: never maxed this one, don't have a track nearby
Those totals were recorded by an ECU monitor, reading directly from the car's own telemetry (not from a possibly incorrectly-installed boost gauge) that records absolute peaks. The higher numbers (14.8) were just a few seconds and there was an immediate falloff; however, the ECU monitor keeps track of spark timing and knock sensors, and I had NO knock and the car did not pull timing when I hit that peak.
Altitude, which of course affects air pressure, is also a factor. Here in Phoenix I am at about 1100 feet above sea level; lower air presure means more PSI = less effect on the engine.
I have mixed feelings about the results. The fact that I am able to boost to 14.8 on a stock TD04/EJ20 and get no knock and no pulled timing (and ignition temp, EGT and oil pressure were within totally safe margins) means I have a solid and reliable engine setup; however, if I am already boosting to 14.8, I probably won't see dramatic results from tuning the engine (ECUTek ECU reflash) without doing a turbo swap. I have an EARLY 02 WRX (I bought it 4 weeks after the cars became available in the US; it was the third to arrive in the state) so it might be possible that the later WRX models have been "dialed back" a bit since then due to feedback from consumers or shops.
Old May 14, 2005 | 01:22 PM
2Stroke's Avatar
Car Info: 2003 WRB Wagon
Absolutely correct. And there are many, many conditions that will affect peak boost readings in a given gear. Among them are how much weight is in the car, whether the road is level, uphill, or downhill, intake air temp, intercooler temp, and car-to-car manufacturing variations in the boost control hardware.
For instance, using an "orifice" (Subaru p/n 22326KA120) with a diameter of .046" instead of the correct .0472" will result in another pound or so of peak boost, and will cause the boost to waver up and down by about a pound when the ECU is trying to hold peak boost. (Ask me how I know...).
My point is that anywhere between 13.5 and 14.5 or so peak boost, in the higher gears, should be considered "normal".
