Sti intake manifold
Old Oct 1, 2005 | 11:21 PM
LdyBigBird's Avatar
Exclamation Sti intake manifold
Does anyone know if a 05 sti intake manifold fits a 03 wrx??? If it does, does it make any difference in performance than stock???
Old Oct 1, 2005 | 11:52 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
it will fit, however there wouldn't be any performance gains. And you would have change out your whole throttle linkage to a drive-by-wire system, which is too much of a headache to do. the reason why you can't keep the throttle linkage is because the wrx manifold is slightly different.
some subaru gurus can back me up on this.
Old Oct 2, 2005 | 06:48 PM
sykosis's Avatar
Yes the 04+ STi manifold is drive by wire meaning there's no throttle cable, just a sensor on the peddal connected to an actuator at the throttle body. The 03 WRX will be a drive by cable system meaning not only would this have to be changed, so would the cruise control system if you'd want to keep it.
castro
Apr 14, 2008 09:52 PM
Renick Motorsports
Engine and Drivetrain
Sep 23, 2006 11:29 PM
Imprezer
Sep 7, 2004 07:36 AM
suafast
Feb 25, 2004 10:13 AM
