sti fuel injectors and walbro pump (with) stock ecu
Old Mar 10, 2004 | 11:49 AM
anthonymx's Avatar
running sti fuel injectors and walbro pumpon stock ecu
if i get those injectors and fuel pump and run it with my stock ecu will it run ****ty?
Old Mar 10, 2004 | 01:11 PM
Mister 2's Avatar
Originally posted by punkrocksailor
it's my understanding that it would run too lean, and who knows how long it would take the stock ecu to figure it out.
Why would it run lean??? The STi injectors flow about 25% more than the stock ones so your car would run very rich when in open loop. In closed loop I don't know how well the stock ECU would be able to cope. Your car would run ****ty without tuning.
Old Mar 10, 2004 | 03:07 PM
anthonymx's Avatar
what if i reset my ecu after installation of the injectors and pump?
Old Mar 10, 2004 | 09:02 PM
anthonymx's Avatar
thanks, i dont have this set up yet but i want to get like a new turbo and i guess i will wait till i have everything to put on the ejectors like ecu and ****
Old Mar 10, 2004 | 10:40 PM
yes, the STi Injectors flow more, but the same currents do not apply, someone more wise than myself needs to step in here and give the technical reasons why. I think it has to do with the ecu still thinking it has the stockers, so it gives the regular signals not revised ones for bigger injectors. I only know this from experience though. I had a ford focus hatchback that I used for auto-x and when I put in cobra R injectors before my ecu was modified to run them I ran lean as hell. then I got the ecu fixed and a supercharger and did really really well.
FWIW,
Joel
Actually the electrical properties of the STi pinks are identical to the stock injectors. The only difference between the two at all is the hole pattern in the endcap. So, if you just put them in with no real engine management, they will run 25% richer all things being equal. If you have a larger turbo, then it depends on how much larger. Either way you will have major idle problems with larger injectors.
Old Mar 12, 2004 | 07:41 AM
Mister 2's Avatar
Exactly what I thought. When in closed loop the ECU would be using the O2 sensor for feedback and it might run (though not too smoothly) and in open loop it'll just be way too rich. In any case you will see a substantial loss in performance until you get it tuned.
Old Mar 13, 2004 | 09:56 PM
Chibby Goku's Avatar
Car Info: Vakamon WRX
I ran PE 800cc injectors and a stock ecu for about 3,000 miles without a problem. However, I never boosted.
Old Mar 13, 2004 | 10:40 PM
Uncle Scotty's Avatar
I don't know from experience, but I have read that if you follow the proper ECU reset procedure after installing the pinks, the ECU has enough ability to adjust to the pinks and will run and idle ok....It can take 7-10 days for the ECU to adjust.
To do the re-set.... from a cold start...let the engine idle WITHOUT TOUCHING THE THROTTLE AT ALL......let it idle untill the fans cycle on/off once....do not touch the throttle....Turn the car off...remove the key....re-start the car and go for a drive easing the throttle slowly to WOT...DO NOT 'STOMP' the throttle to WOT!!!!!!!!!
It may buck and snort some ...but it will eventually learn the trim settings for the larger injectors....It may not be perfect...but it should work.....YMMV...
Old Mar 14, 2004 | 09:56 AM
curbait's Avatar
Car Info: 2002 silver rex
If I remember right running rich for too long could kill your o2 sensor.
Ban Suvs or anyone else How does the walbro pump work compared to the stock pump? Does it start at the same pressure and ramp up higher or something else?
Old Mar 14, 2004 | 11:31 AM
the Walbro raises fuel pressure, and is also capable of flowing a higher volume of fuel at high fuel demand without a huge increase in pressure.
