steam from exhaust system and CEL (was: i have problems!!!!!)
Old Aug 30, 2006 | 06:40 PM
insertchickens's Avatar
Car Info: 03 subaru wrx
starting my car up yesturday and waiting for it to warm up my check engine light comes on. so ok im going down the street no big deal. when i was driving my car start to have alot of stream coming out of my ehaust pipe, and i started to over heat.
i just put water/ rad. fuild in so i dont know.
someone please help what the hell did i do?
any comment will help thanks guys
Old Aug 30, 2006 | 06:45 PM
scoobie8's Avatar
Car Info: 2004 WRX PSM WAAGONE & 1967 vee dub squareback
damn sorry to hear about your prob. You might want to post it in bay area forum as well, maybe someone in your area can look at your car for you!
Old Aug 30, 2006 | 07:42 PM
MO REX's Avatar
Car Info: 02 PSM WRX
Have you checked the coolant since this happendand if so how were the levels? When you added coolant how much did you have to add?
Sounds like a blown a head gasket or cracked the head. Pull the oil dipstick and see if there's coolant in it. If you can get it to Autozone without overheating they can read the code for you. If you get the code post it.
Old Aug 30, 2006 | 08:26 PM
VRT MBasile's Avatar
you can also rent the scanner tool from autozone (requires full price deposit, refunded upon return of tool) that way you can take the scanner to your house without risking the car overheating
Old Aug 30, 2006 | 08:28 PM
you know i put alot of fluid in the rad. on fri the 25th and now there is none. just a week. are the stock heads know to going bad at 60000? i have no big mods to my car. and i was not red lining it or nothing
Old Aug 30, 2006 | 08:31 PM
without a CEL code or inspecting the engine in person, no one is going to be able to help beyond specualtion and assumption. I'd still suggest the autozone scan tool or have it towed to a shop such as gruppe-s
Old Aug 30, 2006 | 08:32 PM
MO REX's Avatar
MBasile
Good idea.
I haven’t heard of many blown head gaskets or cracked heads but that doesn’t mean it doesn’t happen. Did you check for coolant in the oil?
Old Aug 30, 2006 | 08:34 PM
MO REX's Avatar
If he has coolant in his oil you can bet he cracked a head or blew a head gasket.
Old Aug 30, 2006 | 09:01 PM
IGotTheGray_i's Avatar
Car Info: 2005 Subaru
Or mybe just a rediator leak or clogged tubing.. check the simple things first.
Old Aug 30, 2006 | 09:13 PM
i just checked my oil looks and smells fine. when i look under my car its steaming the header meeting the up pipe. then white steam comes out the exhaut. while warming up it sometime wants to stall.
Old Aug 30, 2006 | 09:42 PM
Jakes02's Avatar
Car Info: 2002 WRX
could it be the turbo? cracked housing?
Old Aug 30, 2006 | 09:49 PM
WRX409's Avatar
Car Info: 04 WRX
If he did blow a headgasket than his engine oil after it is contaminated
with coolant should look almost like chocolate milk.
Old Aug 30, 2006 | 09:54 PM
Jakes02's Avatar
Car Info: 2002 WRX
wrx's have chocolate milk makers! sweet.
yeah my integra suffered that fate, it looks pretty gross
Old Aug 30, 2006 | 10:01 PM
WRX409's Avatar
Car Info: 04 WRX
Wink
Sorry to hear that Jake that sucks.
Your WRX is a all around better car.
How did that happen WOT for too long??
Old Aug 31, 2006 | 07:21 PM
MO REX's Avatar
Sounds like it could be the turbo. That's much better than a head gasket.
