starting small to go big
Old Jun 9, 2005 | 11:36 PM
jwrx's Avatar
Car Info: 04 WRX Sedan
Question starting small to go big
i wrote out a list the other night of supporting hardware (only focusing on the engine, drivetrain stuff will be later) i would need for a turbo swap. since i cant drop $4000 into the car right now, i figured i could start small, and start adding the (somewhat affordable) little odds and ends i would need later; mainly, injectors and a UTEC.
i was thinking about putting in the STI 525cc's. would these injectors be able to flow enough to keep a VF30 (in the future, hopefully) from leaning out the A/F? and would i be correct in assuming that i would have to install the new injectors with a utec to keep from running rich? if i just installed the injectors on their own, would the car be livable, or would i be flooding the cylinders and belching black smoke?
one last question! would it be redundant to buy the UTEC and an electronic boost controller?
Old Jun 9, 2005 | 11:44 PM
black smoke would come out
the pinks can keep up
i would just save your money and do it all at once
Old Jun 17, 2005 | 10:04 PM
jwrx's Avatar
anyone know if would it be redundant to buy the utec AND an electronic boost controller? im not going to buy a boost controller if i can get the utec to switch to different boost levels on the fly.
Old Jun 18, 2005 | 05:09 PM
WRX2ndregime's Avatar
Car Info: 2005blackwrx5spd
if you want a utec, and you want to run higher boost maps you will need a boost controller to raise boost levels.
Old Jun 21, 2005 | 12:46 AM
jwrx's Avatar
the utec cant control boost?
Old Jun 21, 2005 | 11:04 AM
it can
i went to 15lbs with me i didnt try to go past that
Old Jun 21, 2005 | 11:05 AM
u tec has a bleed off thing so it does it electronicly and mechanicaly you have to tune both
AssaulTECH
69
Nov 24, 2009 07:52 AM
IS2Scooby
Sep 21, 2007 01:48 AM
sybir
Jul 21, 2005 09:09 AM
bozzwrx
Jan 8, 2004 06:16 PM
Kevex
Dec 1, 2002 06:54 AM
