Starting Problem. HELP PLEASE!
Old Mar 1, 2013 | 01:11 PM
Freakinasian124's Avatar
Car Info: 2004 WRB Wagon
Hey guys,
So, I have been having this problem with my WRX since I bought it about 2 years ago. Every once in a while, I would say maybe once or twice a week, at random times, my car won't start. When I hold the clutch pedal down and put turn the key in the ignition, the car just makes a "VRRRRR" sound. In order to get it started, I keep the key turned in the ignition and I pump the clutch, until eventually it will start running.
I don't know what the problem is, and I am finally just sick of it. In the past, I have tried swapping the ignition and still ran into the same problem. I also thought that the problem might be my battery, but my friends and I swapped batteries and that wasn't the problem.
Anyone have any idea what the problem might be?
Please help me!
Old Mar 1, 2013 | 01:45 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Maybe the clutch switch?
Old Mar 1, 2013 | 02:37 PM
https://www.i-club.com/forums/hawaii...bypass-217999/
Good Alternative?
Old Mar 1, 2013 | 03:13 PM
WRX~Mike's Avatar
My Jetta GLI did the same thing and it was the starter solenoid that was bad.
Old Mar 4, 2013 | 02:24 PM
I got stranded today. I need to buy a starter and get it installed asap.
Will this one work?
Starter by Worldwide (part#17748) / Starters
Old Mar 4, 2013 | 02:35 PM
02RS25's Avatar
Originally Posted by Freakinasian124
had the same prob and bypassed it when i installed a VIper remote start. then took out the viper and left the bypass. that with the combination of a grounding kit...turns over like a hamp!
Old Mar 4, 2013 | 06:02 PM
Also, I forgot to post this earlier.
My car wasn't starting earlier today, It was making the "vrrrr" sound but wasn't starting.
I tried pumping the clutch and it still didn't go.
My friend came to save me and we connected batteries and he jumped me. My car was able to start from jumping.
When I was sitting in my car waiting, I ran a couple electronics and it didn't seem that the battery didn't have enough power.
Not sure if this helps, but it might.
Old Mar 5, 2013 | 02:14 PM
So, I got a video of what happened today.
So I tried to start my car, with no luck at all.
I jump my car and it ran. I drove around for a bit. When I came back home, I wanted to see if it would start at all. and that is where the video starts.
Starting Problem - YouTube
jonsWRX
May 25, 2005 04:30 PM
hYpE-R-29
Sep 16, 2004 03:25 PM
PlatNmRex
Nov 28, 2003 08:32 AM
cmosley
Jan 1, 2003 08:49 AM
Top
