stalling problem
Old Mar 6, 2004 | 07:34 PM
Daredevil's Avatar
you should post this in the WRX powerplant forum
stock turbo with 18psi? holy ****
you might not want to do that.... unless you enjoy blowing things up
Old Mar 7, 2004 | 12:45 AM
go go go's Avatar
Car Info: GF8 ver6
seems like your fuel and ignition is all over the place.
get your ECU tuned properly from a good tuner, good luck.
Old Mar 7, 2004 | 07:30 AM
Wingless Wonder's Avatar
18 psi with the stock turbo is too much boost. At that level, it will be pumping a lot of really hot air. This isn't what's causing your stalling problem, though. Drop the boost and try putting on the stock intake and see if the car runs any better. Have someone professionally tune your car to match your big injectors.
Old Mar 7, 2004 | 01:40 PM
AzN121184's Avatar
Car Info: civic
uhm wth are u doing with 18 psis on stock turbo
have u dynoed the car with 16 psis and found to get more hp/tq with 18 psi's instead?
Old Mar 7, 2004 | 06:59 PM
It's your injectors, and your intake isn't helping either. It's absolutely impossible to outrun the stock injectors on the stock turbo without nitrous or alcohol injection. Put those two items back to stock and go to the appropriate base map (stage 2 TXS I think) and I am 99% sure that will solve your problems.
And yes, 18 psi is too much. Tune for 16 psi. If you tune right your car will be faster than before, even with stock injectors.
intence
Jun 28, 2008 11:10 PM
itzjohnwayne
Nov 4, 2003 07:55 PM
Mayfield
Oct 4, 2003 08:08 PM
Kuth678
Sep 29, 2003 08:20 PM
