Smog question
Old Dec 22, 2005 | 04:28 PM
Project Worx's Avatar
Car Info: 350hp WRX/2008 EVO X
Smog question
I have a catless helix tbe system, and catless up pipe, Im pretty sure this wont pass the visual, but may pass the sniffer am I correct?
My other question is I have my stock 2002 wrx catback will this bolt onto the helix dp, and if so with just the catback i should pass smog correct?
Thank you for any info I can get
Old Dec 22, 2005 | 04:46 PM
subie OCD's Avatar
Car Info: 04 STi
I dont see how a catless exhuast can pass the emissions testing, maybe a high flow cat. Keep your stock exhaust for when the time comes
Old Dec 22, 2005 | 05:59 PM
with just the catback will this bolt onto a helix dp and will I be ok for smog?
Old Dec 23, 2005 | 08:46 AM
subie OCD's Avatar
Car Info: 04 STi
You need at least one catalytic converter after the turbo to pass the emissions in CA. With no cats, you're just spewing raw fumes out...I have no idea about the helix fitment
Old Dec 23, 2005 | 09:59 AM
Me&05WRX's Avatar
Car Info: 2015 STI
+1 You won't pass smog without any CAT... at least one. It's the catatylic that will make you pass, not the catback. Just bolt back on the stock downpipe when the time come. You say you have an 02 so it's been more than 5 years. You will have to do this every year. After five years of the year of the car, the smog check applies, then every year after that. I just recently did my catless setup with helix downpipe with my stock catback, and it fits just fine. You should be able to fit it.
You should opt for a catted downpipe, but then you won't pass the visual inspection. So either way, you won't pass since the law said that you cannot change the catalytic converter, unless damaged or failed, otherwise, it stays... period.
Old Dec 23, 2005 | 01:35 PM
SCOOBYDOOD's Avatar
It's biennial.. every 2 years, not 1.
And since he has an 02, it's only been 4 years, not 5.
Old Dec 23, 2005 | 01:46 PM
subie OCD's Avatar
Car Info: 04 STi
Yeah, Arnold changed the smog laws, but I thought its now 7 years from the year model...? THen biennial
Old Dec 23, 2005 | 02:04 PM
SCOOBYDOOD's Avatar
I'm sorry, forgot to say that, it's actually 6 years, not 5, not 7.
Also, if your car is 4 years old, or newer, you do not have to smog the car when you change ownership.
Old Dec 23, 2005 | 06:28 PM
gmodc7's Avatar
Car Info: nothing
screw arnold and his emissions laws. the real culprit for global warming is action films, not hot subies.
freshrex
Mar 23, 2011 11:46 PM
AWDnutjob
32
Jul 6, 2008 06:06 PM
1sicwrx
Jun 10, 2006 07:32 AM
Rat
Feb 12, 2004 06:46 PM
