should i get the TT?
Old Oct 23, 2003 | 09:07 PM
escaflowne's Avatar
Car Info: 2004 Black WRX wagon
hey. i'm really interested in getting the HKS turbo timer.
not because i need it to keep my car running, but because i want something that does 1/4 mile times, 0-60 etc...
is there something better out there that i should consider? thanks.
oh, i know the Japanese spec type-1 is in km, will it work on our US spec cars? or do i have to buy the US spec. i don't want black!
Old Oct 23, 2003 | 10:06 PM
I have been hearing good reviews about the new G-Tech for its accuracy. It's probably cheaper than the HKS TT and certainly easier to use and install.
Old Oct 24, 2003 | 12:27 AM
escaflowne's Avatar
hm.. who company makes G-Tech. i've never heard of it.
Old Oct 24, 2003 | 12:36 AM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
the G-Tech is the bomb.. its about 1-2 tenths slower then an actual 1/4 run, but its dead on in its measurements
I used to take a 1st gen G-tech I had to the strip with me and run it when I would make a pass, it was a constant .1 second slower, but it was exact every time
perfect for actually timing your mods
Old Oct 24, 2003 | 02:46 AM
my freind had one he said it sucked it was off alot
Old Oct 24, 2003 | 09:05 PM
BanHammer™
the G-tech is very touchy to how you set it up. If you do not do it exactly how it needs to be, it wont be worth more then spit.
when its set up correctly, its on the money every time
Old Oct 27, 2003 | 10:00 AM
theworx's Avatar
Car Info: 04 Java Black Sedan
The new G-tech, version 2 I think, uses GPS to get numbers and is supposed to be extremely accurate. I think it retails for about 200 or so.
Old Oct 30, 2003 | 08:06 PM
Peaty's Avatar
Old Oct 30, 2003 | 10:18 PM
escaflowne's Avatar
i know about the cooling system.
is this why my car keep growling @ idle? it's crazy. goes on and off. sounds like a beast. haha....
Old Oct 31, 2003 | 01:22 AM
madrex's Avatar
Car Info: 03 Rex: HKS, Injen, Apexi, Perrin, Rota
good info Peaty
Hey, i've heard here/there about its cooling capabilities, but your little bit there explained it well. But my concern is not the coolant, its the oil line/lubricated surfaces. Anywhere oil is left to sit and boil in a superhot turbo it can, won't it??? isn't that why we use a TT to let it idle long enough to cool it down so the oil doesn't coke?
sorry to escaflowne for jackin your thread, but we're onto somethin good here, eh...
Old Oct 31, 2003 | 05:11 AM
Peaty's Avatar
The bearing in the turbo has the coolant all around it to take away the heat.
This is a subaru specific diagram:
Also here is a good link:
http://www33.brinkster.com/cammiecam/turbo.htm
And this one:
http://www.spdusa.com/turbo_timer.htm
Old Oct 31, 2003 | 08:06 AM
madrex's Avatar
more great stuff fella
Thanks, all of that info put together helps my brain understand that the "thermal siphon" actually works. The only question I have left is about the oil passages. The engineer gal stated that the oil only flows on the "cool" side of the turbo, but from the cutaway pic, it appears to flow around both ends of the shaft, on both the hot and cold sides. Wouldn't you still have a problem with heating up the oil on the exhaust side?
I already have a TT, so I'm not trying to figure out whether or not to buy one, i just wanna know if it really does anything worthwhile... I still think its a valid component for keeping my engine healthy in a couple of situations:
long freeway drive to work, then a 20 second drive from the offramp to where i park the car. That means i have sustained high EGT's (600-750 degrees C) for about 40 minutes, then I drive down a couple city streets for less than half-a-minute, and then shut the car off.
Any time I run hard and then wanna go park it at home. (i have a great "canyon" run about 15 seconds drive from my house)
again, thanks for your time dude, lots of great info. Bennie
Old Oct 31, 2003 | 09:56 AM
escaflowne's Avatar
Re: good info Peaty
it's cool.
all i wanted to know was if the j=spec turbo timer would work accurately on my wrx.
i don't mind having my acceleration times in KM, i just accuracy.
