scary noise
Old Mar 26, 2003 | 10:57 PM
mmboost's Avatar
The loud screeching noise is the uppipe leak.
jason
Old Mar 27, 2003 | 07:03 PM
Dick Fitzwell's Avatar
sounds like a leak to me....try using shiv's tightening sequence next time.
http://www.vishnutuning.com/files/Up...stallation.doc
Old Mar 27, 2003 | 07:30 PM
very interesting....you will have to let us know how everything turns out. good luck!
Old Mar 27, 2003 | 08:41 PM
i have to agree here. not to contradict what you or the dealer is saying, but i honestly think it's a leak at the uppipe as well. i wouldn't get all crazy assuming it's your turbo until you have made sure it isn't a leak.
Old Mar 28, 2003 | 09:46 PM
EtchyLives's Avatar
I am getting a lower opinion of Subaru techs everyday. I went in with what turned out to be a bad spark plug. Even after checking the code and dfinding a misfire code, the guy went on and on about my "disconnected EGT probe" and how it had probably "broken off and got caught in my turbo" and that's why I had no boost.
This brilliant deduction came AFTER I had to explain "limp mode" to him.
That screeching noise is an uppipe leak. It's the same sound a loose DP makes when a bolt falls out. Sounds HORRIBLE. Just take it off, and follow Vishnu's uppipe install guide to the letter and you should be alright.
-Etch
Old Mar 29, 2003 | 05:56 AM
Turbox's Avatar
Did you check for a cat under the hood?
