Saving money on oil changes
Old Mar 14, 2004 | 01:46 AM
GO24JUNIOR's Avatar
Car Info: Subaru WRX 2002
Hey guys it's Mike again I wanna save money on my oil changes cause I wanna pamper my baby so I'm going to strickly synthetic oil but I know to get those kind of oil changes it cost some money so, my question is how do I change the oil on my WRX. Do I just simply drain the oil and replace the filter and pour new oil in just like any other car? Just curious I hope this question isn't stupid. I'm aware that the OEM filters are probably the best bet for oil filters but what about oil what's the best there. Thanks for the help guys.:banana: :banana: :banana:
Old Mar 14, 2004 | 03:18 AM
DLUX WRX's Avatar
yeah, same as any car. and as w/ any other car make sure the seal come off w/ the oil filter (sometimes they stick to the car) and use a new crush washer when you reinstall the drain plug. as for the oil, i use Mobil 1. its pretty much the best stuff you can get at regular oil prices.
Old Mar 14, 2004 | 04:09 AM
Mulder's Avatar
Car Info: 02 WRX WRB
Yes, that's basically it but a couple of things-
First, note which is the correct oil filter for your car because there was a change for the 03s due to the proximity of the filter to the downpipe, Subaru went to a smaller filter. You can check with your dealer to see which one your car should use, there are also threads on this subject on NASIOC and probably here as well. Once you know which filter is the right one you don't have to return to the dealer every time, a Purolator from the parts store is fine since they make the OEM filters anyway.
Second, because of the orientation of the filter on the engine (upside down) you can pre-fill it with oil before installing it. This ensures the engine has oil pressure almost immediately when restarted following the oil change, since the pump won't have to first fill the filter before pressurizing the rest of the engine.
Old Mar 14, 2004 | 06:02 AM
04blkWRX's Avatar
Car Info: Black WRX, stock
Theres a real good thorough tutorial here: http://www.scoobymods.com/forums/sho...&threadid=3014
Old Mar 14, 2004 | 11:15 AM
GO24JUNIOR's Avatar
Ok so where is the oil filter located on the 02 WRX and where is the drain valve located? and about how many quarts of oil do I need to fill the engine back up? Thanks guys:banana: :banana: :banana:
Old Mar 14, 2004 | 01:51 PM
MO REX's Avatar
Car Info: 02 PSM WRX
I was told you can safely go 4500 miles on synthetic if you change the filter @ 3000. Does that sound right to you guys?
Old Mar 14, 2004 | 01:54 PM
MO REX's Avatar
If you have your owners manual it should tell you. Im lazy and pay to have it done since my mechanic checks everything while its in for oilchange.
Old Mar 14, 2004 | 11:26 PM
GO24JUNIOR's Avatar
What are Diffs?
Old Mar 15, 2004 | 01:29 PM
ride5000's Avatar
i think mulder meant to say proximity to the rh exhaust manifold collector, not downpipe; the downpipe is some distance away.
also, even though you can prefill the filter very well, i like to go one extra step... i disconnect the crank position sensor and the cam position sensor and turn the car over for about 30 seconds to fully prime the oil system. then i reconnect sensors and away i go. the cel which illuminates from the temporarily disconnected sensors goes away in 3 driving cycles.
hth
ken
evsoul
18
Oct 26, 2006 12:44 AM
taction
May 12, 2005 11:28 AM
wimp580
24
Jul 27, 2004 03:02 AM
