Samco Turbo Inlet Hose
Old Jan 20, 2006 | 04:47 PM
Chip18's Avatar
Does any modification need to be done to the Samco turbo inlet hose to make everything fit and work properly? Just wondering cause I want to know what I am in for before I buy one and install it. By reading the reviews on here it doesn't sound like the Perrin inlet hose is a wise investment. Does the Samco inlet hose have all the right connections so I don't have to cut apart the hose as well as the stock inlet hose? Also has anyone heard anything good/bad about the GP Moto turbo inlet hoses? They look identical to the Samco one, but are $100 cheaper.
Here is a link to where I found both of them.....
http://www.oakos.com/Merchant2/merch...egory_Code=300
Thanks,
Chip
Old Jan 20, 2006 | 06:10 PM
Jizzo_02SubiWRX's Avatar
Car Info: 07SubiWRX
i have a samco turbo inlet hose on an 02 wrx. it fit right up on all the vacum lines. its kind of a ***** to put on at first cause of the intake manifold.
Old Jan 20, 2006 | 06:14 PM
Chip18's Avatar
I have heard that these are a pain to put on that is why I am putting this on at the same time as the new turbo so there will be a little more room to work with, or so I hope.
Old Jan 21, 2006 | 04:08 PM
Chip18's Avatar
Anybody else have any thoughts on wether this is a good move buying the samco inlet hose or not with a VF34 turbo?
Old Jan 22, 2006 | 01:04 AM
i have the GP moto. the vaccume line for the blow by came off on mine so i used a hose clamp
and the vacume line on top ripped on me so i RVTed that
the hardest thing is the allen on teh top side on the intake manifold for me
Old Jan 22, 2006 | 07:20 PM
Guerrilla's Avatar
Car Info: 02 WRX
I was looking at the Perrin hose...what have you heard bad about it? I saw the GP Moto pipe has all the connection on it, does the Perrin? It didn't quite look like it...
Old Jan 23, 2006 | 09:50 AM
Dice's Avatar
Car Info: 2002 WRB WRX
I've heared that the perrin has some fitment issues. Im looking into the avo turbo inlet and if I cant find get that, then a samco. I think I remember hearing something about aps making a metal turbo inlet like the avo if thats not to pricey, look into that.
Old Feb 3, 2006 | 04:15 PM
El Supremo's Avatar
$269.00
http://www.vividracing.com/catalog/p...ducts_id/19652
Supremo
Old Feb 4, 2006 | 10:02 PM
meilers's Avatar
I think the silicone rubber inlets are just asking for trouble -- you don't want flex in that part of your inlet, just where the air turns a corner. The stock inlet is rigid for a reason; the acordion pleats are for strength and to keep it from collapsing, not just because it is a cheap part.
I watched some "tuner" show where they were making some minor mods to a EV0 VII and they replaced the turbo inlet hose with a silicone hose, although due to the transversal mount of the motor the hose was almost three feet long. They put the car on the dyno and you could see the hose buck, bulge and strain -- that can't possibly be good. That APS part is awesome, but also extremely expensive; I'd have to have it feeding a $1200 APS turbo to make it worthwhile.
Old Feb 4, 2006 | 11:49 PM
lovesmysuby04's Avatar
Car Info: 06 STI WRB/Gold
$275 for the APS piece compared to 300 or more for the samco. Not expensive when you compare these two but still if you are going to buy one get the new APS unit. Plus with the APS unit you get two different size couplings(standard/3-inch) for different turbos and I think you get a silicon maf hose too.
Turbo86
Oct 21, 2006 10:08 AM
froggy
Aug 13, 2006 04:31 PM
Ash
Sep 22, 2004 09:51 PM
mhlady
Mar 18, 2004 08:41 PM
East Coast WRX
Nov 19, 2003 05:00 PM
