samco or perrin turbo inlet
Old Oct 28, 2004 | 07:07 PM
DanyoCantDrift's Avatar
The weal amewican hewo!
i am thinking about purchasing a turbo inlet, but just wanted some feedback or opinions on these two types...is there any performance difference between the two? one easier to install then the other? other types of inlets that might be better...ne info would be great...thanx guys
daniel
Old Oct 29, 2004 | 01:59 PM
Donkey's Avatar
Car Info: 02' WRX
They are basicly the same thing.Same goes for the intercooler hoses as well
Old Oct 29, 2004 | 02:57 PM
dubbRX's Avatar
just curious, wat are benefits of getting those hoses?
Old Nov 5, 2004 | 01:58 PM
gordy's Avatar
Car Info: '03 WRX WRB
the perrin is definately an easier install because of the way they relocated the nipples. if its not the only thing your installing or don't mind the extra work check out the avo
http://www.avoturboworld.com/avoshop...roducts_id=144
it gives you one smooth fat piece all the way to the airbox. where as the perrin and samco ones connect to the stock accordian junk and if you want to replace the accordian piece there is only the samco maf hose which is another $100 and doesn't fit quite right with the perrin piece.
Old Nov 5, 2004 | 02:48 PM
Speed Element's Avatar
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
Daniel- I'd go w/ the Perrin; much easier to install than the Samco Hoses. I can cut you a great deal on one, so just give me a PM when you decide you want the Perrin unit.
-Soren
Old Feb 25, 2005 | 07:25 PM
Jimpreza's Avatar
Car Info: truck
Question
Hey Soren,
Is this true? The samco MAF hose doesn't connect right to the Perrin inlet hose?
Jim
Old Feb 26, 2005 | 07:39 AM
Former Sponsor
Jimpreza- I haven't seen any problems connecting a Samco MAF hose to the Perrin Turbo Inlet hose, so I don't believe that's the case.
-Soren
Old Feb 28, 2005 | 10:04 AM
gordy's Avatar
it fits on the perrin inlet side fine.. its way way oversized on the airbox side. I had to cut it a bit shorter to get it to fit snug, and then I had to pull it very tight and clamp the hell out've it which makes getting into my airbox to change the filter a big headache.
91vtec
Apr 19, 2014 01:35 PM
WrX89
Hawaii Classifieds
Nov 12, 2013 03:24 AM
VTRZA
Mar 27, 2011 07:34 PM
NORCAL STI
Mar 30, 2005 07:29 AM
Ash
Sep 22, 2004 09:51 PM
