Regular (87 Octane) Gas in WRX?
Old Apr 4, 2004 | 02:37 PM
ilivas's Avatar
The manual reccomends 91 octane I believe. An off the shelf octane booster will give you like .01 of an octane point so it's pointless.
Old Apr 4, 2004 | 04:37 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
Originally posted by Mach5WRX
Use 87, if you don't like boost.........
Old Apr 5, 2004 | 08:48 AM
No, it recommends 93, but 91 octane is okay.
Old Apr 5, 2004 | 08:51 AM
ish's Avatar
ish
Originally posted by BAN SUVS
Guys, if you can't afford the extra $3-4 per tank of gas, you need a cheaper car.
If you absolutely positively cannot get any 91 to out in your car you can run at 89 or even 87 for s hort time. You have to stay out of boost and out of full throttle. This applies even to Cobb's 87 octane map. DO NOT buy an AccessPort for the purposes of running 87 octane. For one thing, you're spending $500 to save $3 a tank... duh. For another, the car makes no boost on that map and timing is pulled so far you'd get walked by a Neon... a 5 year old ex-rental Neon.
Trust me on this- if you want to save gas money, drive less. Consolidate trips, drive slower, no "fun runs" on the backroads, and find a way to stay out of the car more often.
yeah exactly what kevin said. if you can't afford the extra couple bucks, sell the car and buy a civic.
Old Apr 5, 2004 | 12:56 PM
Kean's Avatar
Car Info: 03 WRX / 08 Forester
For the WRX it says to use "premium unleaded gasoline with an octane rating of 91 AKI or higher. If premium unleaded gasoline is not available, regular unleaded gasoline with octane rating of 87 AKI or higher may be temporarily used."
Old Apr 5, 2004 | 02:43 PM
SilentSLJ's Avatar
Car Info: 02wrx wrb COBB stage II, 93 Nissan Z, 98 Honda Prelude SH, blah, blah, blah who cares
Hallelujah, Amen,
If you want to use 87 buy a used neon.
Old Apr 6, 2004 | 05:26 AM
SilentSLJ's Avatar
I've got an 88 Honda Civic dx. I commute to work in it and I usually get around 38mpg, & I use 87. Plus I don't care who parks next to me or taps my bumper or, or, or etc. Then on weekends I drive my Sube
p.s.
I think I paid $1,100 for it.
Old Apr 6, 2004 | 11:34 AM
2bluewagons's Avatar
Car Info: 2004 wrx wagon
Where can you get 93 around here (NorCal)?
Old Apr 6, 2004 | 11:58 AM
Kean's Avatar
91 is usually all you can find here in California. However, there are some Unocal 76 stations (and others) that sell unleaded racing fuel and/or you can use an alternative such as toluene. I have a local 76 that even sells 100 octane at the pump here in Mission Viejo (So Cal). Keep in mind that 91 octane is perfectly fine in the WRX as outlined in the owners manual (as I pointed out earlier):
- Kean
Old Apr 6, 2004 | 12:05 PM
doodoobrown's Avatar
there's a few places in the bay that sell 100 octane gas
https://www.i-club.com/forums/showth...ighlight=sunol
Old Apr 7, 2004 | 05:23 AM
ftnssn's Avatar
Car Info: black pearl sti
87 octane is definetly bad and you really shouldn't mix octanes if you can avoid it. Octane boosters are bogus, just do the math. Into a 15gallon gas tank you pour 1q of liquid and its going to boost your octane level? Only if its rocket fuel.
Old Apr 7, 2004 | 07:35 AM
SilentSLJ's Avatar
Plus rocket fuel is solid anyway
Old Apr 7, 2004 | 08:28 AM
Kean's Avatar
....and you really shouldn't mix octanes if you can avoid it.
why?
Old Apr 7, 2004 | 03:04 PM
Mister 2's Avatar
I think it might be 0.1
In any case octane booster isn't worth it. Many people have the misconception that since it claims to raise your octane 1-2 points that it can turn 91 octane into 92 or 93. What it does is make it 91.1 -91.2.
