Quick gasket question...
Old Mar 22, 2005 | 11:09 AM
turfshark's Avatar
...long explaination.
i recently purchased a dc sports exhaust and it has worked out great but the flages are rusting (like others according to the review post). anyway, i would like to keep it so i want to wire brush the rust off and primer the flages. i would like to make sure i get it all so i want to remove the exhaust to do it. where is the quick question you ask?
after i remove the exhaust, do i need to put new gaskets on the pipes or can i use the orignals assuming they come off in good shape?
tia
Old Mar 22, 2005 | 11:01 PM
turfshark's Avatar
uh, sorry what i meant was...which bov would be the most kick ***?
or, should i use a cold air intake or not?
j/k, i know my question is not the most glamorous, but a little help would be appreciated. thanks.
Old Mar 23, 2005 | 08:10 PM
turfshark's Avatar
hello? <knock knock> is this thing on?
Old Mar 24, 2005 | 10:12 PM
troll's Avatar
Car Info: 2002 WRX
For a catback, you shouldn't need new gaskets. If you replace the downpipe, BUY A NEW GASKET. If you don't, there is a very high probability that you will get leaks. I have found that it is basically impossible to reuse either uppipe or downpipe gaskets without leaks. They don't cost that much, and it is really inconvenient/annoying to have leaks.
hYpE-R-29
May 8, 2013 05:52 PM
Heedz
Feb 28, 2013 12:56 AM
hYpE-R-29
Sep 10, 2012 05:12 PM
Irish_car_B0mb
Feb 18, 2011 12:47 AM
DarkJuic3b0x
Feb 3, 2011 10:55 PM
