questions about ej257 SB
Old Dec 4, 2004 | 11:02 PM
240sxer's Avatar
well i got a ej257 SB going in my car soon.. the part that concerns me are that i am still using stock ej20 heads and cams.. will it totally hinder the performace of my car using these? this upgrade wasnt totally planed.. old motor gave out so i got this to get it running again.. some say it runs fine.. some say it runs like crap, others say it needs cams and not much else and the rest say it needs head work..
anyone can help me on this subject?
thank you
Old Dec 4, 2004 | 11:41 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
I cannot remember, but I think the compression will either be too low or too high if you use STi shortblock and WRX heads.
Old Dec 5, 2004 | 03:24 AM
240sxer's Avatar
i dont recall, but i think with the pistons i am using it will be around 8..5 to 1 or something..
which isnt to low or to high
just worried that my heads wont flow well enough to support the increased displacement and that my cam profile will be totally wrong for this set up..
Old Dec 5, 2004 | 12:13 PM
Imprezer's Avatar
Admin v2.0
Well, you did not say anything about having different pistons.
P.S. What is up with people asking a question and not providing all the info.
Old Dec 5, 2004 | 03:59 PM
240sxer's Avatar
haha whoops!!
jdm ej20 heads (off a 96/7 wrx)
ej257 block
cp pistons
bpm crank/rods
stock turbo
fmic (but 02 wrx tmic/bov is on it right now)
intake
uppipe
downpipe
catback
link ems
550cc injectors
255 walbro
haha back to the question, will everything flow ok? or should the heads get a nice port job and get some nice cams.. if they flow ok should i just get cams?
thanks
Old Dec 6, 2004 | 05:22 PM
ds baruuuuu's Avatar
Car Info: 5.4RS
everything should flow fine i would be more worried about using the stock turbo on that notor then the heads...
Old Dec 6, 2004 | 09:43 PM
240sxer's Avatar
yeah i know, that is an easy fix.. the heads are more of a concern at this moment.. since the motor has to be pulled and parts removed to install the heads/cams.. turbo.. i can just unbolt a few things and stick it (sorta)
if you get my drift..
i havent gotten much replies in the areas ive posted or to the people ived talked to.. lets say about.. 15 people// about 4-5 said it should be fine with no real problems (2 of which are running the set up but one has cams) the rest thinks there might be some issues.
Old Dec 8, 2004 | 05:05 PM
Car Info: 5.4RS
i havnt tried the set up but a guy here is running an sti block stock wrx heads and cams and isn not havin any problems
Old Dec 8, 2004 | 11:16 PM
240sxer's Avatar
i know people use v7/8 heads.. but do they find a way to hook up the avcs? how do they run with out it?
TheMason
Nov 11, 2003 10:00 AM
GO24JUNIOR
Nov 7, 2003 01:05 AM
O 16581 72452 5
Sep 18, 2003 09:37 PM
View Askew
Jul 16, 2003 12:03 PM
