Question on a DP
Old Jan 28, 2004 | 11:22 AM
sKOOTeR WRX's Avatar
Car Info: WR Blue WRX
Question on a DP
I just recieved my downpipe from a vendor on ebay ( it was cheap and the design was just like the turboxs) I can't show me better detail of many of the DP except for the APS high flow which looks like it has the bung in the side of it.
My question is that the pipe I recieved has the O2 bung back toward where the pipe connects to the midpipe. Is the harness for the o2 sensor going to reach this far or should I have a new bung welded in?
-skooter
Old Jan 28, 2004 | 11:43 AM
mario's Avatar
It should since my TXS TBE O2 bung is on the end of the high flow cat. That is really far back, it is so far back that i had to snip some zip tie connection thing to get it to reach tug on the wire a tad where it had slack.
Old Jan 28, 2004 | 12:08 PM
Salty's Avatar
should be long enough to fit if you have a MT. if you have a 4EAT then the tranny is too wide and it might make the wire seem shorter (happened to me)
Old Jan 28, 2004 | 12:13 PM
mario's Avatar
Checked his profile thank god he has a 5MT
Old Jan 28, 2004 | 12:27 PM
esracer's Avatar
Car Info: 2002 Honda S2000
I'm guessing this is the same for the HKS downpipe, meaning that there will be no problem putting the O2 sensor back in. Is this right?
Old Jan 28, 2004 | 12:40 PM
mario's Avatar
I think the only way to tell for sure is to actually install the down pipe. I'm sure any answer we try to give you is an assumtion since you bought a down pipe that know one probaly has. Just go for man :banana:
Old Jan 28, 2004 | 12:44 PM
Salty's Avatar
it's true.. maybe SOA accidentally cut your O2 sensor lines too short. who really knows just install the damn thing.
Old Jan 28, 2004 | 12:48 PM
I just wanted some opinions from others that have done the install just so I didn't pull everything of and start cursing at the car when things didn't fit.
Basically I just want to know what to expect.
-skooter
brucelee
Aug 1, 2009 10:59 AM
legacy2003
Jun 8, 2003 04:43 AM
