Question about stock(?) boost
Old Jan 9, 2004 | 03:18 AM
dcmomentum's Avatar
Car Info: 2002 WRX White, 2005 STi Black
Guys,
I just purchased a 2002 WRX used. It came with an autometer boost gauge installed. It runs at vacuum while at idle, but in all gears boost is about 13.5lbs. I checked under the hood, and see the stock T-fitting where a boost controller would be mounted. Any thoughts?
Old Jan 9, 2004 | 06:04 AM
theworx's Avatar
Car Info: 04 Java Black Sedan
What exactly is your question? Stock boost is 13.5, so you are right on the money.
Old Jan 9, 2004 | 08:53 AM
dcmomentum's Avatar
OK great, I kept reading that everyone wanted to get full boost in 1st and 2nd gear. And the negative boost at idle is normal too?
Old Jan 9, 2004 | 12:44 PM
theworx's Avatar
Negative "boost" is normal at idle, normally read in mmHg(millimeters of Mercury). It is the amount of air(read by pressure) that the engine is pulling in to run relative to atmospheric pressure. (Imagine the pistons drawing in air when the valves are open and piston is moving away from valves.
PSI is the amount of air, in pressure, the engine is seeing that is being supplied by the turbo relative to atmospheric pressure.
If you ever want to confuse someone tell them that your car runs 28 PSI of boost stock. 14.7 psi of atmospheric "boost" plus the 13.5 PSI of additional boost supplied by the turbo.
Hope this helps.
Old Jan 9, 2004 | 12:45 PM
theworx's Avatar
The ECU limits boost in first and second.
Old Jan 9, 2004 | 01:22 PM
Daredevil's Avatar
reflash/tuneing
Old Jan 9, 2004 | 01:26 PM
dcmomentum's Avatar
Right, my question was really if it was normal to get full boost in all 5 gears without any visible mods.
Old Jan 9, 2004 | 03:58 PM
mmboost's Avatar
Visible? Yes. A reflash would be virtually undetectable and could be done to give you greater boost in lower gears.
jason
Old Jan 9, 2004 | 04:05 PM
dcmomentum's Avatar
Maybe that's why I get full boost in all 5 gears? Is there any way that I can tell if my ECU has been reflashed, so that I can cross that off my to do list?
Old Jan 10, 2004 | 05:52 AM
theworx's Avatar
Have the dealer scan it. They would be able to tell
Old Jan 10, 2004 | 06:07 AM
MonkeyAB's Avatar
Car Info: 2001 Impreza 2.5RS(Ti)
However they may void your warranty if they know your ECU is reflashed.
Old Jan 10, 2004 | 01:31 PM
dcmomentum's Avatar
I bought the aftermarket bumper to bumper warranty, so I should be ok. Plus I bought it from that same dealer, I doubt they would give me an issue, b/c they are the same people that sold me the car...
Old Jan 10, 2004 | 07:14 PM
theworx's Avatar
Unless they knew it had a reflash when they sold you the car, they can still deny the extended warranty you bought. Take it back to a different dealer to get it checked out.
Old Jan 11, 2004 | 02:44 PM
New2MeSuby's Avatar
Car Info: 2007 Mazdaspeed 3, Black, 6spd
I sort of have the same deal. Sometime about 50% I get 13.5 psi in first. I bought the car used and stock. I don't know whats going on with it.
freshrex
Aug 25, 2008 01:59 AM
yzercyber
Aug 12, 2005 03:42 PM
kts262
Jan 24, 2005 07:11 AM
rebbaz
Jan 22, 2005 08:52 PM
Acadian
Dec 20, 2004 05:05 PM
