question about helix up and downpipe
Old May 21, 2003 | 08:24 AM
dan avoN7's Avatar
2006 Mt Hammy Car Show Winner
Car Info: Black 03 WRX, White 04 E46 M3
yes the helix flex uppipe is catless, thats the point of an aftermarket uppipe to remove the cat.
yes it fits perfectly with the stock turbo
the helix uppipe comes with a bung for your egt sensor so either put the stock one back in or plug it and do the 2.2k resistor mod. For the uppipe you will need to get a MIL eliminator.
by doing the resistor and mil eliminator you wont see any bad sideeffects. It is just simply telling your ecu that the readings are good so it won't send your car into limp mode.
The uppipe and downpipe are good first mods, order it now and enjoy the power
Old May 21, 2003 | 02:59 PM
dan avoN7's Avatar
the resistor is for the uppipe 02 sensor, that only requires a little cheap resistor to fool. The mil one goes for the downpipe and is basically more wires and more advanced for tricking it. The gruppe-s uppipe is great, lots of people say it's great and haven't had any leaks. Thats the uppipe i am buying as soon as summer starts (parents said no modding till schools out). As far as power gains, all uppipes will give you the same results since it is just a pipe. The reason people buy flex pipes is because the flex supposadly doesn't leak as easly. It gives the pipe room to move a little. If you are really worried about leaking go with the flex, but the gruppe-s is really a good pipe and will save you some money.
Old May 21, 2003 | 03:06 PM
dan avoN7's Avatar
oppps forgot about your egt question. If you dont want to put the stock sensor back in and do the resistor mod you can put your greddy egt in, but thats not recommened. The readings aren't as accurate on the uppipe so i would tap in your exhaust manifold.
ChuiSti
May 6, 2008 07:41 PM
gruppe-s
Engine and Drivetrain
Aug 11, 2006 05:34 PM
nathanellis
Jan 14, 2005 04:08 PM
