Pulley or I/C hoses????
Old Oct 8, 2004 | 11:28 AM
DKS_Subaru's Avatar
Question Pulley or I/C hoses????
I have TurboXS stage 4 sitting in my room (vf34, sti pinks, walbro fp, full exhaust, Utec). I was wondering if, since i have the upgraded turbo, that the i/c hoses be a better mod than the pulley? Even if the hp gains are the same, wouldn't the hoses stress the turbo less? I understand a pulley is supposed to add even more hp with modded engines...any suggestions?
Old Oct 8, 2004 | 12:20 PM
DaWorstPlaya's Avatar
Car Info: WRB 2003 WRX
Both are great mods but for what you have I would say the I/C hoses would probably help a little more. I hope you are doing the uppipe as well =) ....... anyways why not do both as they are on the cheaper end of mods. I have a lightened Vishnu underdrive pulley with belts if you are interested and new hoses are only $120 shipped and second hand ones are cheaper ....
https://www.i-club.com/forums/showth...093#post697093
PM me if you are interested ...
Old Oct 8, 2004 | 01:55 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
I would also go for the I/C hoses.
Old Oct 8, 2004 | 02:01 PM
Jumpman23's Avatar
Car Info: 2004 PSM WRX
i third them ^^^^ go wih the i/c hoses, get better airflow and get rid of that nastyass restrictive stock one
Old Oct 8, 2004 | 03:39 PM
RussB's Avatar
Car Info: $200,000 sports car
ic hoses make a big difference with the vf34, I went with the perrin set. it actually fits the vf34 better than the stock hose. i wouldn't even bother with the bov bypass hose as it's a major PITA. i didn't even put on the throttle body hose, just the y hose.
Old Oct 8, 2004 | 04:56 PM
mysterymarker's Avatar
Car Info: 2004 WRX
how hard is it to install the pulley?
Old Oct 9, 2004 | 09:10 PM
Pulley is very easy to install 30mins max ....
Old Oct 14, 2004 | 12:18 AM
psychobooe's Avatar
Go with the hoses. The pulleys just scare me, too many questions that are still unanswered.
pscyho
Old Oct 14, 2004 | 12:42 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
+1 for hoses.
Old Oct 14, 2004 | 01:54 AM
Group B's Avatar
Dahveed aka Robin Hood
I know for a fact that the Perrin lightweight pulley does improve throttle response, but since the stock pulley is rubber-isolated, I wouldn't mess with it.
Messing with your pulleys and Flywheels can cause probs with your crank bearings in time.
Old Oct 16, 2004 | 01:13 PM
nerrad5's Avatar
Car Info: 02 WRX WRB 4EAT VF34 Kit w/AP
I had the pulley in my hand, and last minute took them back and got ic and maf hoses. Same reason as above. Too many unanswered questions.
Old Oct 17, 2004 | 10:54 PM
JDM SiR's Avatar
Car Info: 2004 WRX
Go for the I/C hoses. Lightweight pulleys, like lightened flywheels, have been known to sometimes trigger cylinder misfire codes on the stock ECU.
tofuman
Jan 10, 2012 10:06 PM
Yin
Feb 22, 2005 04:14 PM
titsataki
May 11, 2004 01:25 PM
TXBlueBeast
Wanted
Jan 28, 2004 05:48 PM
