Prodrive 3-Port Boost Solenoid??
Old May 17, 2006 | 03:07 PM
spectra's Avatar
Car Info: 2003 WRX Blue
I am looking at Boost controllers and I found this one by Prodrive 3-Port Boost Solenoid. It says for use of an aftermarket engine management. I am using the COBB Access Port I wonder if this would be a good one to go with or should I look only at the Manual Boost Controllers like the Turbo XS High Performance Boost Controller. Here is a like to the Prodrive Boost Solenoid; http://www.oakos.com/Merchant2/merch...gory_Code=7000
Any help would be great.
Old May 17, 2006 | 04:03 PM
duo's Avatar
duo
Car Info: WRB WRX 2004
you would need a protune with that solinoid. Otherwise you will get all kinds of crazy boost spikes. Out of curiousity why do you want a boost controller when you already have a accessport. That basically does the job of the boost controller. The only thing the 3 port solinoid will do is a bit better spool up and better off to on throttle response. Also save yourself some cash and get the gm solinoid. Same thing less expensive
Old May 20, 2006 | 09:22 AM
valeo is stamped on the prodrive
and duo is right
SubieFoo
Dec 1, 2009 08:52 AM
DomozitoLK
Aug 6, 2009 02:39 PM
strider327
Feb 20, 2009 10:09 AM
ChadG
Oct 29, 2008 03:05 PM
alee86
Oct 24, 2007 08:58 PM
