problem with 2 different MBC!
Old Feb 24, 2004 | 09:27 PM
minisiu's Avatar
hello,
I bought a " Core" MBC from ebay ($39.99 +shipped) and installed it. It has alot of problems.
first, it is hard to adjust.
2. It spikes
3. it run loew boost with the engine is cold.
so i end up take it off.
and today i bought another one for my friend, and he has a 1 g dsm and he sold his MBC to for $10.00 the org. $ was 49.99
he got it from dejontool.com
and it also has alot of problem
1. Spikes
2. when i hit the gas qickly it boost dam good but when i hold the gas it run low about 8psi.
Does any MBC like this|???
well, i am pertty sure i install it right!
Wich MBC you guys use and it has no problem!
I already spend 50$ i don'r spend another 100$ and end up with the same problem!
Plz help
Old Feb 24, 2004 | 10:33 PM
Uncle Scotty's Avatar
If your car is an '04 DO NOT USE AN MBC. You may kill your engine real quick....things that work on the '02-'03's KILL '04's
If you don't have an EGT gauge---DON'T USE AN MBC either.
Old Feb 25, 2004 | 01:33 AM
Daredevil's Avatar
get gauges
get reflash
don't get mbc
Old Feb 25, 2004 | 01:22 PM
theworx's Avatar
Car Info: 04 Java Black Sedan
I can attest for the no MBC with an 04. Mine ran like **** with it. Pulled timing everytime I hit the gas which made the car slower than stock. I since have given it away and ordered an Access Port. Should be here in a week or so:banana: :banana:
FuturistiK_STI
Jun 30, 2011 08:45 AM
xrwits04
Mar 22, 2008 08:06 PM
tamashi523
Oct 29, 2007 09:33 AM
Gixxer750
Aug 3, 2004 12:33 AM
