Power on little $$
Old May 3, 2003 | 02:58 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Originally posted by toekneepark
uppipe... got your stock uppipe if you're looking to save some money, but make sure you do it thoroughly... and maybe an MBC?? 30 bucks... not bad..
I 2nd the uppipe. However getting it reflashed if you have an ecutek is a little pricey Also an MBC is not recommended with a relfash from ecutek
Old May 8, 2003 | 02:49 AM
kyoung05's Avatar
Get the Gruppe-S up pipe as someone mentioned earlier. A new exhaust is going to cost anywhere from $500-$1200, and don't get a catback since they do close to nothing as far as performance goes. Maybe you can scrape together $600-700 and get the TSX Stealthback? But for $225, Gruppe-S will install their up pipe, with new gaskets. That comes out to $139 for the up pipe, and $85 for the install. MPJ charges $150 just for the install, so you do the math. And since they are doing the install, you know it won't leak, and you'll have saved yourself 6-7hrs of labor. Then you can use $20 (probably more with the shipping) to have Cobb reflash your ECU. Just a thought...
________
VAPORIZER AFFILIATE PROGRAMS
Old May 8, 2003 | 07:46 AM
capt'n'caveman's Avatar
Car Info: platinum rex wagon
Re: reflash
Originally posted by prodrive121
love the reflash....But
As they say boost is like crack you think you want more (you dont) but you just cant stop and in the end it will kill you.
Any opinions on the gains to be had from:
Port matching
Throttle body modding
new plugs
turbo porting
Finnaly who has the quieter turbo back exhausts.
Im thinking: port out the thing for better top end and do the turbo back W/ new reflash from cobb... any draw backs Leaning out #3 cyl?
unless you have the tools and knowledge to do those mods for free, they ain't going to be cheap, nor will they yield you and noticable gain........unless you have some high hp numbers and mods to support those mods
the reason everyone is pointing you to the exhaust is because, unlike NA car......freeing up the exhaust flow will net you some big gains
free the UP first, cuz the the first cork in the road....plus it does nothing but restrict your flow after warm up.
