post uppipe downpipe install - sounds
Old Nov 24, 2002 | 12:13 AM
whiterabbit's Avatar
Installed uppipe and downpipe this past weekend.
I get this noise when I get into boost. Can't really tell where its coming from. Sort of high pitched. I thought it was turbo whine at first but its kinda loud. If i rev up the car while not in gear (neutral or just with clutch in) it is perfectly fine, no sound just normal exhaust note.
Is this a symptom of an upipe leak? I am praying that it isnt.
thanks
Old Nov 24, 2002 | 08:12 AM
nqwan's Avatar
Car Info: o2 duburu arr exu
can you compare the loudness to anything? i think its just the turbo spooling.
Old Nov 24, 2002 | 12:32 PM
yea I thought if it was an uppipe leak I would hear it in neutral. It doesnt get worse or better when the car gets warm either.
Just as soon as the car starts boosting it will start. Kind of like a screech sound.
I'm goin to check the factory EGT today and hopefully get under the car tomm to take a look.
Is it possible to have a leak cause I tighted everything too much?
Old Nov 24, 2002 | 01:28 PM
IgotWRXed's Avatar
Car Info: ayo for yayo
i was aboot to say egt. i remember posts like this over on NAZIOC and it turned out to be the egt probes fault. also, when you are in neutral/clutch in, there is no boost being generated, so it could be turbo related if u only hear it whilst in boost.
Old Nov 24, 2002 | 07:43 PM
no smoke coming from the car... 12k miles on the car
borrowed a tq wrench. Goin to give everything retightening tommorow to 26ftlbs
any suggestions?
thanks
Old Nov 25, 2002 | 08:09 AM
did u just get thicker gaskets and it went away?
