possible to flip my fmic around?
Old Sep 19, 2004 | 10:35 PM
Long_Travel_WRX's Avatar
Car Info: stock 04 wrx sedan
yea thats right my fmic got a lil bashed in i was thinking of just flipping it around and put some sorts screen on it, i dont see what the difference is? anyone tried this? or know someone? seems to me it will be the same
Old Sep 19, 2004 | 10:39 PM
bassplayrr's Avatar
I had to do that with the frontmount in my grand national with no ill effects. As long as your mounting points will still work it should work just fine.
-Chris
hiding the "blitz" will help with the popos as well.
Old Sep 19, 2004 | 10:42 PM
yea they are the same i thought the top L bracket was welded soild to the top on the cooler but i checked and its bolted so it will rotate around
Old Sep 19, 2004 | 10:59 PM
bassplayrr's Avatar
Then I see no problems. It's not like your changing the direction of flow through the intercooler, you just changing the direction of outiside air over your intercooler, and the fins/bars are not uni-directional.
-Chris
Now get to work!
Old Sep 27, 2004 | 07:44 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
Arent the inlet and outlet piping pointed inwards towards the car ? If not I see no problems.
Rush
Old Sep 29, 2004 | 07:48 AM
240sxer's Avatar
if you dont wanna do that, just remove the "BLITZ"
Old Sep 29, 2004 | 09:51 AM
AzN121184's Avatar
Car Info: civic
Originally Posted by jdmwrxsti
What about the "Blitz"? Is the same thing writen on the other side?
i think the blitz is just sprayed on by the owner with stencils. I've seen blitz IC's without the logo.
Old Sep 29, 2004 | 10:15 AM
Zoeb2s's Avatar
I <3 White Girls
The problem is not with the top bracket, but you may run into problems on the side brackets...I looked at mine b/c I was thinking of flipping it around (so the black sides wouldnt show) but Davon noticed on mine that the holes for the brackets on the sides come out a little more (they are not centered) You might still be able flip it, but it will not sit the same way...not sure if it will come out more or go in more though.
Also modified brackets would probably fix that.
Old Sep 29, 2004 | 02:38 PM
SsTiNgEr77's Avatar
Car Info: 2002
no i dont think you can flip your fmic around... better to sell it and buy a new car
Old Sep 30, 2004 | 04:27 PM
AWD 20T's Avatar
Car Info: 2009 G Ride
James, why not take an hour or so with a pair of tweezers or a mini-screw driver and bend the fins straight again? Problem solved.
Old Sep 30, 2004 | 09:19 PM
WRX Rush's Avatar
Or you could also use a radiator comb. I didn't even think of it. . . .good call AWD 20T
Rush
Old Oct 1, 2004 | 01:27 PM
dan avoN7's Avatar
2006 Mt Hammy Car Show Winner
Car Info: Black 03 WRX, White 04 E46 M3
yea thats what i do every week when i wash my car. It works for the occasional bent fins but when you have a pretty big spot where they are all bent its impossible to get that new look back.
Old Oct 3, 2004 | 11:03 AM
awns729's Avatar
Car Info: want a WRX
Would it be possible to cover the IC with some sort of mesh grill type thing?
Old Oct 3, 2004 | 11:25 PM
dan avoN7's Avatar
yes but i think it looks pretty ugly when you do that. My friend has mesh infront of his fmic on his eclipse and i hate it.
