Please help, I F#*@!ed up...
Old Nov 25, 2002 | 05:21 AM
Dick Fitzwell's Avatar
that sux! how long where you foolin' around before this happened, any noise from the tranny??
Old Nov 25, 2002 | 05:47 AM
bamfwrx's Avatar
Car Info: 02 WRX
Making a wild guess here everybody step back
could the shift rod have gotten bent?(the rod that moves when you shift between the shifter and the trans)
Old Nov 25, 2002 | 05:54 AM
Slvrblt's Avatar
Originally posted by jwrx02
With the clutch all the way in, the shifter will simply NOT go into first. It seems like you can shift into second, but as soon as you let the clutch out it pops back into neutral making a slight grinding noise. all the rest of the gears work just fine, clutch feels the same while letting it out and moving.
j
sounds like what happened when I went through 1st and 2nd gear
if you haven't passed your warranty period (and you don't have any mods that could point to the destruction of the tranny), they should either refurbish the screwed gears- or give you another tranny- can't hurt to try
speed safely
Brian :devil:
Old Nov 26, 2002 | 04:42 PM
stealth-wrx's Avatar
yeah new tranny time.
