A pillar Gauges
Old Jul 6, 2003 | 10:28 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
Boost, EGT, Oil pressure
Old Jul 7, 2003 | 03:41 PM
BanHammer™
EGT and A/F meters are prolly the most needed gauge in a turbo car. Although they both do about the same thing, you need to be careful with your EGT even if you have a good Air Fuel ratio. I remember when RoadRace was just using a AF meter and were still melting pistons due to the fact that even though they AF showed them running a good mix, the EGTs would spike after a long race and still do damage.
With a good EGT, you can still tune your fuel mix and keep an eye on your temp at the same time, that’s why I recommend a EGT before a A/F meter. If you have room, run both, if not, the EGT is most important.
ViperWRX
Sep 25, 2009 09:38 AM
atomicapples
Oct 30, 2003 12:46 PM
CLsmooth71
Feb 26, 2003 06:31 PM
CLsmooth71
Subaru OEM Parts For Sale
Feb 26, 2003 02:54 AM
