pictures of my motor and car
Old May 18, 2003 | 07:45 PM
stealth-wrx's Avatar
hope you like them.
Old May 18, 2003 | 07:54 PM
DeliciouSpeed's Avatar
Oven spray will remove the purple anodize from the BOV cap.
Looks good. Tell us about the mods that round out the car.
Old May 18, 2003 | 08:05 PM
hmmm, here are some of the mods:
basically here is my engine set up.
2.2 liter closed deck block
2.5 crank shaft making displacement 2.35
big bore iron ductile sleaves making displacement from 2.35 to 2.5
forged rods
forged pistons with swain coated skirts and tops
arp head studs
wrx heads
custom swain coated vavles
5 angle valve job with custom spec seats
custom spec buckets and shims
fully ported and polished heads
sti tvg housings
wrx intake manifold
gt spec turbo manifold
perrin fuel rails
3" exhaust with one huge resonators and a greddy sp muffler ( very very quiet)
blitz front mount intercooler
when i break it in i will be switching these parts:
stock turbo to a garrett ball bearing to4r
stock injectors with PE 800 cc's
stock ecu with an autronic smc2
custom downpipe
custom up pipe adapter
tial 40 mm wastegate
new fuel rails with 310 fuel pump and -8 lines
aero motive fuel pressure regulator
Old May 18, 2003 | 09:01 PM
hmm, right now i dont think it puts out very much. i am hoping for 500+ wheel hp when i am done.
Old May 19, 2003 | 07:32 AM
You should check out the MRT rails, I'll be running those with a Bosch pump from a Z, and the same Aeromotive FPR.
Head work-What was done to the combustion chambers? Can the chambers size be increased to the 99mm bore without going into the water jacket?
Old May 19, 2003 | 08:22 AM
andyhidley's Avatar
Car Info: 2002 WRX
That crappy CA license plate is blocking 40% of your FMIC air. A relocation is in order, or fill the plate with little tiny holes!!
Nice job!!!
Old May 19, 2003 | 08:54 AM
the license plate is so i dont get tickets. as soon as i break the motor in i will be using my own custom fuel rails with -8 lines and a 310 denso pump. the combustion chambers were slightly enlargened to 51.1 cc's, but you can only go a little bigger.
Old May 19, 2003 | 11:22 AM
What bore are you running? Have the chambers been matched to the new bores?
Old May 19, 2003 | 11:54 AM
andyhidley's Avatar
Car Info: 2002 WRX
Hummm You said WRX heads, 2.5 jugs... I'm assuming the heads are from a 2.0?? Anyway, what kind of headgaskets fit big jugs and small heads?? Or is the head surface large enough?
Old May 19, 2003 | 01:01 PM
the bore is 99.4 mm and i am using custom 2.5 5 ply metal head gaskets. the head surface is plenty big enough for the block. the chambers have been modified a little to match but not much. with modify it it only is about 2 mm around over hang.
Old May 20, 2003 | 04:29 AM
andyhidley's Avatar
Car Info: 2002 WRX
stealth-wrx... Thanks
Old May 20, 2003 | 07:09 AM
Thanks for the info.
Ken
Old May 20, 2003 | 03:44 PM
mysubaruimp's Avatar
Car Info: 2001 sub. imp.
can we say "sleeper"
