oil question
Old Aug 13, 2003 | 02:37 PM
in3g_wrx's Avatar
Car Info: white 03 sedan
oil question
is it better to run thick oil such as 20w50 or is it better to run thin synthetic oil such as 5w30?
Old Aug 13, 2003 | 07:19 PM
brento's Avatar
Car Info: 02 RS
most of use in hawaii are running 5-30 or 10-30. we aren't that tropical that you need such thick oil.
plus with thinner oil you get better milage.
Old Aug 13, 2003 | 11:37 PM
mmboost's Avatar
10w30 seems the best bet. Mobil1 Synthetic. Thats what I ran at ThunderHill Raceway (~100F) with no problems.
jason
Old Aug 16, 2003 | 05:34 AM
Turbox's Avatar
Smile
Synthetic Oil has the ability to withstand more temperature extremes than conventional oil; this it's main advantage. The most imporatant thing is to change your oil every 5000 mi or less depending on how hard you push your vehicle. I personnaly run synthetic in my WRX.
Oil viscosity should be kep to the manufacturers recommendation. In this case I Run 5-30 in Winter, 10-30 in Summer. I beleive subaru even allows 10-40 in summer.
It used to be common practice to use 20-50 or even straight weight oils; 50! However, what you need to consider is that the bearing clearances on todays production engines are much tighter than 20-30 years ago. the heavier weight oils do not flow in the bearing surfaces if the clearances are not large enough.
Bottom line. Use synthetic if you can afford it, changes your oil regularly, and use the recommended viscosity on a production engine.
TurboX
ASE Certified Master Technician
Old Aug 16, 2003 | 12:13 PM
psychobooe's Avatar
Hey TurboX,
I'm living in Colorado right now. I've been using 10w-30 all year round. Should I be using 5w-30 in the winter?
Thanks for the help.
psycho
Old Aug 16, 2003 | 03:22 PM
Turbox's Avatar
I only use 5-30 in the dead of winter. Our last winter here in New Jersey was on the cold side, many weeks below freezing. 10-30 is fine, however, the engine will turn over a little easier when its very cold with 5-10 making for easier starts. the protection level is the same for both
TurboX:
Old Aug 17, 2003 | 02:00 AM
in3g_wrx's Avatar
what kind of oil would you recommend if i live at a tropical area...hawaii
Old Aug 19, 2003 | 03:23 PM
rhk118's Avatar
Car Info: '03 Black Sedan
I talked to a rep at Amsoil about this when researching oil...they make high quality synthetics used in aviation but you can buy for cars as well (having said that I'm still using Mobil 1)....you can let this oil go for for like 30,000 miles if you change the filter every 10,000 or so to 'clean it up'...(not that this sounds Subaru Warranty friendly...will do it when the warranty is done)...
Anyway here's what he said specifically about the WRX:
5w-30 if you live in an area with cold temps (i.e. 4+ months of winter) like in New England where I live (-35 F this winter, 82 F today)...no problem to use it year round (as I do)...
10w-30 if you live in warmer areas or areas that don't see below 40 F that much...or switch to 5w-30 for those months that are cooler.
He said the 'special weight' oils (0w-40, 0w-50...etc.) only drain your wallet if you're an everyday to consistently aggressive driver...they only offer more protection under very specific situations and everyday use of the WRX turbo is not it...
Hope that helps!
Old Aug 19, 2003 | 08:16 PM
in3g_wrx's Avatar
anyone got any input in penziol synthetic 10w-30?
Old Aug 20, 2003 | 04:22 PM
bryan's Avatar
Been using Amsoil for years. Great product....
