Oil Leak somewhere...saw oil on top of intercooler
I <3 White Girls
I have an 02 WRX with ~ 3500 miles on it. Yesterday i opened my hood and saw oil building up on top of my intercooler, its not a lot, but there should not be any, right?
I looked around, but i couldn't trace it. Any ideas on where it could be coming from?
I have an appointment at green valley for some other small stuff, but im not sure i want to leave it with them for an oil leak.
If its something minor i rather just do it myself thats why im asking.
Any help would be appreciated.
Thanks,
Zoeb
Thanks,
Zoeb
Re: Oil Leak somewhere...saw oil on top of intercooler
Originally posted by 02BlackWRX
I have an 02 WRX with ~ 3500 miles on it. Yesterday i opened my hood and saw oil building up on top of my intercooler, its not a lot, but there should not be any, right? I looked around, but i couldn't trace it. Any ideas on where it could be coming from?
Keep in mind that any oil buildup on the top of the intercooler would almost have to originate from underneath the unit, because the intercooler has that seal that mates up to it from the hood scoop. Did your hood scoop 'ingest' anything (is there any oil on the outside of the hood scoop)?
There is no oil on the outside of the hood at all.
Oil/filter changes and minor suspension mods, I'll do. I don't mess with leaking engine seals - that's what warranties are for.
Here's a link to one article about the GReddy oil catch can, which PimpWagon has mentioned, and others have talked about in unrelated threads.
http://www.2phast.com/porsche/Corvette/catchcan.htm
IMHO this doesn't fix the problem - just a band-aid fix for the symptoms. A mildly modified EJ20 shouldn't be producing that much blowby past the rings to create a problem for the engine seals. I'm not familiar with the crankcase ventilation system on the EJ20, but other engines had PCV valves which sometimes got stuck.
I <3 White Girls
do you suggest i put the stock BOV back on before taking it to the dealer or do u think it would be ok to leave the aftermarket one on?
I ahve seen my self and other WRX's here that have a lot of oil blow by and it builds up around the joins from the turbo to intercooler hoses and y-piece so are u sure u haven't got any loose clamps around any of your hoses or throttle body or where the BOV bolts on??
Check your BOV, the oil is most likely coming from there.
A catch-can as mentioned above should allieviate this .
the PCV gasses contain oil and it's most likely coming out your BOV because it was on it's way to be burned before you took your foot off the gas.
I <3 White Girls
I looked around the blow off valve, but i didn't see any oil over there...as for the throttle body etc... i haven't even touched those so I can't see oil coming out from over there. I think i'll just let the dealer **** with it. Do you guys think having an aftermarket blow off valve will give me trouble at the dealership?
Thanks,
Zoeb
Thanks,
Zoeb
Speed Element
Vendor Group Buys/Specials
Jun 3, 2003 10:56 PM
