oil cooler
Old Nov 24, 2003 | 09:24 PM
Wingless Wonder's Avatar
Someone makes an adapter that sandwiches in between your oil filter and the engine. It takes hose fittings for the inlet and outlet of the oil cooler. I'm thinking Greddy but I have to check it out to be sure.
And by the way, suberacer, please keep your smack comments to yourself. If people knew the answer off the top of their heads, I'm sure they'd post.
EDIT: The adapter I remember was advertised for the EJ20 - don't know for sure if it'll fit on an EJ22. What car is this in?
Old Nov 24, 2003 | 10:14 PM
robb's Avatar
Car Info: 2003 Silver WRX Sedan, 1982 Corvette Collectors Ed.
Originally posted by suberacer
aaaawwwww what’s the mater all you hard core engine builders and tuners out there only know about bolting on stock replacement stuff...... i.e. (HKS / Apex / Blitz) and don’t really know anything about tuning or racing your subies....
Uh, dood.
For some reason I don't think this will expedite the reply process...
Huh? What was that? Hey guys I think I just heard the migratory call of the great smallpeckered trollbird....
In other words be nice or the mods may migrate you the "other" forums.
Old Nov 25, 2003 | 05:19 AM
Origami posted by
my car is a 2000 impreza...
<snip...>
Man, that's a lot of stuff on your car! I would sure like to check it out sometime.
Anyway, getting back to your question concerning oil coolers - ScoobyMods.com has a mod to install an oil pressure gauge from an existing tapped hole on the EJ20 block, underneath the factory TMIC. Maybe this plug is also present on your block. Wherever you end up tapping into the oiling system, just make certain that the oil line just doesn't dump into the oil pan, otherwise your oil pressure will go almost to zero. It has to be plumbed back into the system somehow.
If you can't find the specific answer you're looking for, you might check with shops that specialize in race build-ups of Subaru engines, such as for sand drags or rallying.
