octane to hp question if anyone knows?
Old Feb 3, 2003 | 10:19 AM
stealth-wrx's Avatar
assume you have a bullet proof engine and great flowing heads, factory cam, t-66 turbo, all the fuel and proper tuning in the world ( to some extent) whats the most hp you could pull out of california 91 octane winter gasoline. i am asking because i want to know if its possible to get 400 at the wheels on pump gas. if you dont know my build up here is some quick info:
ej22 built with 2.55 liter displacement
fully done up heads
t-66 turbo
800 cc injectors
i am going to use an autronic ecu
Old Feb 3, 2003 | 10:47 AM
mmboost's Avatar
Wouldn't that more be a product of what you can and need to boost to get to 400hp? A larger turbo gives you move power with same/less boost, right? So 400hp on a TD04 (if possible) would require more boost than 400hp on a T66, and therefore more combustion retarding higher octane fuel. Make sense?
So what's my freaking point? I dunno if you can get a straight answer, or at least a straight corollation between HP and octane. I would think, however you could get a straight(er) corollation between boost and octane.
Do you know the boost you need to run on your system to get to 400hp?
jason
Old Feb 3, 2003 | 10:52 AM
i have no idea, i was hoping you knew
Old Feb 3, 2003 | 03:41 PM
mmboost's Avatar
I don't remember now... but I know that with some base line numbers (like the hp from a stock EJ25 with whatever compression it has) you can extrapolate the 2.25 hp and then extrapolate to the hp for a given addition of boost.
I don't remember it... but at least you know the calculations are possible It might be in Maxiumum Boost by Corkey Bell. I'll look it up later.
jason
bignb408
Apr 8, 2009 10:24 PM
SPT_TRBO_AWD
May 9, 2005 05:58 PM
rota wheels wrx
Sep 6, 2004 04:57 AM
Need4speed
Mar 29, 2004 11:31 PM
