no temp reading
Old Dec 30, 2005 | 09:28 PM
lightning_wrx's Avatar
Car Info: 2002 Subaru WRX
Exclamation no temp reading
i just replaced my radiator tonight and me and a friend drove around for at least 5 hours and then on the way home i happened to notice that the temp gauge was on cold. after it was running at the right temp for that long. I turned the heat on and it was blowing cold air. does that mean that something is wrong or is it just the gauge. thanks in advance
Old Jan 2, 2006 | 01:16 PM
any body i need to drive the car tomorrow to work and i dont want to overheat my engine
Old Jan 2, 2006 | 01:35 PM
psoper's Avatar
250,000-mile Club President
Car Info: MBP 02 WRX wagon
I trust you filled it up with coolant, tightened all the hoses and all that good stuff?
And the levels are still OK in the overflow tank?
You drove it for 5 hours and it didn't show temperature or seize up?
Tough to say without digging around under the hood, but are you sure all the sensors are still hooked up?- that still wouldn't explain the heater not working though...
How far away is work? if it survived 5 hours in this state, I'd think it's either about to die for real or it's probably fine to get you to work.
If the temp was OK for a while but now it isn't, and you didn't pop a hose or have some other massive coolant loss of some kind, you probably had a lot of air in the system that got burped out during your drive.
Double check the levels, I'd expect to find it a few quarts low, top it off and you should be OK.
Island Style
May 26, 2006 08:59 AM
gordy
Oct 27, 2004 03:03 PM
bambams247
Aug 21, 2003 08:34 AM
forcefed
Aug 10, 2003 09:53 AM
whiterabbit
Nov 24, 2002 08:01 AM
