Newbies first post - lifter adjustment
Old Mar 4, 2003 | 08:05 PM
Enginerd's Avatar
Car Info: Silver '02 WRX Wagon
I read somewhere (can't remember exactly) that 02+ WRX engines have solid lifters. If this is true, I imagine they need periodic adjustment. How often should this be done? 30k? 60k?
Old Mar 5, 2003 | 01:36 PM
cnstman's Avatar
Car Info: 2004 Silver/Silver STi
does an dohc engine even have lifters? i thought the cam lobes are in contact with the valves. maybe i have it all wrong??
cnstman
Old Mar 5, 2003 | 02:02 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Yes there are solid lifters. The factory service manual does not specify a service interval for them although it does describe the procedure to check and adjust clearance. I have heard the first inspection for the valves is supposed to be at 100K although I don't have documentation on that.
Old Mar 6, 2003 | 03:01 AM
Wingless Wonder's Avatar
There is a small lifter with a thin shim to adjust clearance. Shims are available to adjust a range of clearances. The procedure looks pretty straightforward as long as you have enough room to work. The service manual specifies a shim replacer tool.
^ww^
"…axles of evil…" - George W. Bush
Old Mar 6, 2003 | 06:43 AM
cnstman's Avatar
thanks
thanks for the description of the system.
cnstman
Old Mar 10, 2003 | 08:32 PM
Enginerd's Avatar
Thanks all
Thanks to everyone who replied. I asked because on very cold mornings (5-10F) I can hear a little valve clatter for ~30sec after startup. I guess that is something I should expect with solid lifters.
soggynuts
Jun 14, 2004 07:49 PM
nelsonzhang
Sep 26, 2003 10:01 AM
TurnWRX
Sep 8, 2003 09:29 PM
WRXRN
Mar 11, 2003 01:41 AM
