New turbo installed w/o supporting fuel....max 8psi?
Car Info: 03 WRX Spec R1
Hi,
Yesterday I had an SR40 added to my TXS Stage 2+ uppipe (map) setup...with no injectors or pump added (they are on their way).
The car is only running 8psi with the UTEC in open loop mode...no matter how I adjust the ABC. I was told this may happen...but what can I do to add a bit more (safe) power until the other items arrive. Lets say run 12 or so PSI to be safe...?
BTW for 8psi the car is actually pretty darn fast...not as fast as the stocker/stg 2 at 16psi but I cant wait to get this SR40 running at 18PSI...
Anyways, any input in the interim is appreciated.
Thanks a lot,
Brian Broz
Thanks a lot,
Brian Broz
seri_808
Aug 19, 2006 01:06 AM
DrVortex
Aug 7, 2006 08:32 PM
wrxraybrand
Aug 9, 2003 08:48 PM
