Is my pulley harming the (EJ20) engine?
Old Mar 23, 2006 | 12:06 PM
ImpWrx007's Avatar
Car Info: 2002 subaru Impreza WRX
Is my pulley harming the engine?
i have an 02 wrx. I have a vishnu stage 0 kit on it that i put on in 02. the kit came with a pulley amongst other things how does everyon efeel about vishnu and is the pulley harming the engine? i am looking to put it back to stock, i want a nice commuter with descent gas mileage? should i leav ethe pulley on or take th e***** off? help
Old Mar 23, 2006 | 12:10 PM
flipmode's Avatar
I say leave the pulley because with a lighter pulley the car does not have to work as hard. When i put mine on i noticed that the rpm dropped a cruising speed on the highway and engine response improved with stop and go driving.
Old Mar 23, 2006 | 12:51 PM
cudaeh's Avatar
Car Info: 2000 impreza 2.5 rs
leave the pully
some say that since the underdirve pullies arnt a harmonic ballincer there is a risk of shattering your crankshaft because of the imballance.
Others say that your barrings and seals will wear out quicker because of the vibration of the crank shaft not being ballanced. Personally I have run the cheepest pullies you could ever imagine on every car I own and have never encountered these issues....
Come to think of it I have never had any issues with underdrive pullies.. on any car Ive owned. other than remembering what size belts I needed when replacement time came around.
As far as proformance gain from it.... I have fount it to be placebo.. thinking your car is accelerating quicker than normal... but I guess people have actuall number to back up gains. I phrased it like this to demonstrate the diffrance to my friend. I held the ballancer pully in my hand and rotated it back and forth, I then did the same to the light weight one. It was obvious that I could rotate the light one alot quicker than the ballancer one... That has to be saving your engine work some where.
Old Mar 23, 2006 | 09:39 PM
Wingless Wonder's Avatar
I've had the Vishnu pulley on my '02 for at least 50,000 miles - no ill effects so far. As for performance improvement, I can't tell (but it shouldn't be any worse ).
Old Mar 28, 2006 | 03:00 PM
ImpWrx007's Avatar
much oblidged fellas
JDMcarBOY
Jul 3, 2011 03:00 AM
demonbugeye
Hawaii Classifieds
May 4, 2009 03:26 AM
bluebiker
Jun 22, 2006 10:41 AM
Brfatal
Oct 20, 2003 10:31 PM
