my loves to drink gas
Old Feb 9, 2004 | 04:13 PM
SnoHumper's Avatar
Car Info: sc300
just a guess, but........ are you sure your not losing compression?
Old Feb 10, 2004 | 07:05 AM
andyhidley's Avatar
Car Info: 2002 WRX
Does italy have "leaded fuel" ? does your car take unleaded due to a CAT?
Also I would check for some type of damage that happened in shipping. Perhaps a hose that got pulled off around the gas tank area due to improper tie down???
How about a crushed exaust pipe? or a smashed CAT and the inside fell out and clogged the exaust? via driving over a ramp and bottoming out on the exaust?
Assuming uncle sam shipped it for you?
Food for thought, worth checking....
Old Feb 10, 2004 | 04:11 PM
sKOOTeR WRX's Avatar
Car Info: WR Blue WRX
I would suggest checking the exhausgt gas backpressure. Sounds like a melted CAT the same thing happend to me and it just kept getting worse and worse until the car no longer would drive above 40mph.
Best way to check backpressure is to unscrew an O2 sensor and screw/insert in the gauge. Anything above 1~2psi is bad.
Good luck to you
-skooter
Old Feb 11, 2004 | 04:56 AM
andyhidley's Avatar
Car Info: 2002 WRX
"The plugs run hotter"? I'm not sure if you have an identical cross referance or not between the two plugs... But If the plugs are too hot then the motor will have detonation issues. Perhaps not with 96 octane. But Octane is measured differantly in differant countries. Thus What octane is it really?
Changing the thermostat is not a fix for too hot plugs. And changing the coolant formula is also not a fix for the cause (cause being too hot plugs, as you stated)
Old Feb 11, 2004 | 12:36 PM
TurnWRX's Avatar
stupid question but is there a lot of stop and go traffic/roads?
Over here in sf, the constant stop and go roads get me about 14-16 mpg stock.
Old Feb 11, 2004 | 01:39 PM
SuboobaruWRSEX's Avatar
Car Info: Viper ACR & H1
Take out the hotter plugs, and put stock temp or cooler in. Do you have a header? Bigger hills? Lead foot implant? Temperature change? If it is colder you will get worse gas mileage.
Nick
foothill5
Mar 3, 2009 01:33 AM
kidatari
Sep 9, 2004 12:22 AM
Siris
Feb 15, 2003 02:21 AM
Hiroki
Dec 3, 2002 06:50 AM
