Motor mounts?
Old Apr 6, 2004 | 06:50 AM
Ditty77's Avatar
Car Info: 2002 WRX
Motor mounts?
Who has motor mounts and how's that going?
cost?
install?
do anything?
Old Apr 6, 2004 | 10:54 AM
i was going to get them but then they say you need the tranny ones too. there is more noise and vibration when you put them on
Old Apr 6, 2004 | 11:44 AM
r_master's Avatar
Car Info: PSM WRX
i have both engine and tranny mounts and got them installed on the same day so i can't say what engine mount itself will do...
like sigma pi said, it increases cabin noise due to more vibration transfering over due to stiffer mounts, but with stiffer mounts you can put more of those power to the ground.
you know when you start your engine, the engine moves? with stiffer engine mounts less movement, more power to the tranny... and eventually more power to the ground
as for the mounts go check out www.mpjperformance.com or ask for mike on the phone.
if you live in bay area, CA call gbmotorsports for installs.
Old Apr 6, 2004 | 09:47 PM
mmboost's Avatar
And that energy has to go somewhere... I was considering getting them but after giving some thought as to where the energy goes, I figured it puts more stress on an already dubious transmission. I'll put up with the power loss for having a transmission that lasts a bit longer
jason
Old Apr 6, 2004 | 11:18 PM
SsTiNgEr77's Avatar
Car Info: 2002
jason is sayin
that every little bit of stress will cause more wear and tear, how much is the question?
but overall i think its a good mod, I'll be getting mine soon -_-)b
Old Apr 7, 2004 | 02:02 AM
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
Re: Motor mounts?
cost?
install?
do anything?
i assume u mean the polyurethane ones? my friend ordered the ones from spt.subaru.com, not sure if those are poly or not though. he's running basically a stock set up. . . but in terms of "subjectiveness" the car feels a little more solid in the "get go"
i may be wrong... but like i said-subjectively speaking.
try looking @ www.spt.subaru.com
Old Apr 7, 2004 | 06:11 AM
ride5000's Avatar
given a crappy driver, sure, the tranny MAY last longer with squishy mounts.
i prefer to shift correctly AND have my mounts!
jm2c
ken
Old Apr 8, 2004 | 03:46 PM
Ditty77's Avatar
Car Info: 2002 WRX
I installed the motor mounts & tranny mount at the same time and I love the way the car reacts now.
Hard hittin! :banana:
Old Apr 8, 2004 | 04:00 PM
robb's Avatar
Car Info: 2003 Silver WRX Sedan, 1982 Corvette Collectors Ed.
Re: Motor mounts?
I tried taking mine out. The car ran like crap - so I put them back in.
I suggest keeping them.
Old Apr 9, 2004 | 11:01 AM
Ditty77's Avatar
Car Info: 2002 WRX
Re: Re: Motor mounts?
Old Apr 11, 2004 | 08:00 AM
pimpUall's Avatar
Car Info: '04 WRX Wagon
It's not true that it put more power to the ground. It makes the engine react faster. Instead of the mounts compressing or moving it goes to the drive train faster. It get rid of some of the drivetrain wind up. I had to put a solid mount on my '56 Ford pu(built chevy 327). The motor would torque so much it would rip the motor mount. But, I had fun doing .
Old Apr 13, 2004 | 12:17 AM
bassplayrr's Avatar
robb and his "straight face."
Old Apr 13, 2004 | 12:22 AM
bemani's Avatar
Car Info: 02 WRX/05 Legacy
jason
The energy gets transfered by the harden mounts to the chassis of your car ... if anything, I say it should be better for the transmission, since the engine no longer flops around, taking the transmission with it. With the mounts, everything stays in place as they should.
Old Apr 14, 2004 | 11:11 PM
DJTEN4's Avatar
Car Info: 03 yellow wrx
ok so it sounds like i want this lol but i spend way too much money as it is, so how much would they be installed.... maybe i should just call mpj because mike gives good deals!!!!! but i have no idea what the cost is for this stuff like it could be anywhere from 30-300 in my mind help me out, is it worth it?
