Modding For Better Gas Mileage?
Old Mar 9, 2004 | 11:27 AM
esracer's Avatar
Car Info: 2002 Honda S2000
YOU HAVE A FREAKING SPORTS CAR WHO CARES ABOUT GAS MILEAGE!!!!!! lol jk:banana:
lets see adding an exhaust system and adding a more efficient flowing air filter most of the time gets better gas mileage, not by much though. Things that let the engine run more efficiently helps gas mileage. The best mod probably would to put like a brick under the gas pedal so that you can't slam it down and go fast lol. Well that's all I have to add to this.
Raymond
Old Mar 9, 2004 | 11:52 AM
esracer's Avatar
Originally posted by WickedSpeed
Hey, that brick under the gas pdeal idea is GREAT, Raymond.
Thanks! lol I would use that mod for myself, but.....I just have too much fun going fast!:banana:
Old Mar 9, 2004 | 12:17 PM
CharT's Avatar
Car Info: 2003 WRX Wagon
ECU remaps will help gas mileage by leaning out the cruising air/fuel ratio. You could also disconnect the turbo and have an N/A 2.0L engine.
Old Mar 9, 2004 | 12:44 PM
DanyoCantDrift's Avatar
The weal amewican hewo!
why oh why would you want to disconnect the turbo though LOL
Old Mar 9, 2004 | 09:32 PM
nic3krnnamja83's Avatar
hey how does wider tires reduce gas mileage
Old Mar 9, 2004 | 10:51 PM
namakemono's Avatar
Car Info: gc w/ neons and a wrx that needs neons
don't use your AC
Old Mar 9, 2004 | 11:56 PM
soundwave's Avatar
more than meets the eye
Car Info: ?
remove your spare tire, don't date fat chicks, don't fill up you gas all the way but 1/2 instead
Old Mar 10, 2004 | 12:26 AM
zunus's Avatar
It means that you have more friction between the car and the ground so that requires more power to move the car than you would with skinnier tires. Also wider tires weigh more and the more weight you have in your powertrain the more power is needed to do the same thing. More power needed means more gas needed. Wider tires have more traction though, so you corner better, and grip during takeoff better.
Think of rolling a bike tire around a corner. Pretty easy, very little resistance. Now try to roll a dragster rear tire around that same corner. Probably aint gonna happen because it requires more power to move that big tire. More power means more gas in the engine. Thats an exageration but you get the idea... I hope
Old Mar 10, 2004 | 12:40 AM
Wingless Wonder's Avatar
Origami posted by CharT
The original post didn't state what type of subie they are driving (incomplete member Profile).
You probably wouldn't like driving a WRX with zero boost. Its low compression necessitated by the turbo would mean sluggish off-idle response and with no boost it would also be weak throughout the RPM range. An RS2.5 would eat it for lunch.
