max power from stock turbo
Old Jul 29, 2003 | 07:54 PM
boloheadrat's Avatar
You answered your own question. Most people say the stock turbo will fall out of it's efficency range around 15 psi. They also say the neighborhood of 280hp is all a stock turbo'd WRX can safely produce, irreguardless of injectors, EM, whatever.
Old Jul 30, 2003 | 03:16 PM
verc's Avatar
Car Info: GT35R, Meth
Well what you COULD do,
is do some really really really specific calculations for your car.
Figure out some Pressure ratio: (Boost+1 ATM)/ 1 ATM
and flow rates of your engine:
CFM = [(liters)*(rpm)*(Volumetric efficiency)*(pressure ratio)]
5660
VE would be around 90 percent-ish (use 90 in the formula, not .90)
Remember to compensate for Altitude,humidity, and temperature when calculating pressure ratio!!!
And then go look @ a compressor flow map
Then plot the path your car would take in each gear under different load.
Then go plot an "ideal line" w/ the most boost possible while still staying in the efficiency range of the turbo.
To make the long story short, go to your really expensive EBC and make gear/rpm specific boost. You *could* make as much psi as the fuel system and flow and the stock internal components can physically endure, so you could program say 1.5 bar @ 5000 rpm, which would be ~400 cfm through the turbo. Now I have NO idea how much the stock TD04 can flow but @ 7300 rpm fuel cut, you'll be @ almost 600 cfm which I know the TD04 can't flow.
Anyways you can max out your stock turbo by making the turbo make MAX possible efficient boost under every rpm and engine load condition.
Old Aug 1, 2003 | 03:03 AM
secretaznboy's Avatar
Originally posted by nitro
a 16G wheel??? what is the stock one? and you are referring to the compressor wheel right?
You said capacity... so you mean with the right upgrades the stock turbo would be good for up to 350 hp(crank?). how whould that affect spool up? and $400, is that for porting the intake/exhaust housing and the 16Gwheel?
So upgrades I would probably need would be a bigger top mount intercooler(btw what is the stock intercooler good up to?), bigger fuel pump and injectors(how big of fuel pump and injector?), and a reflash or a piggyback to handle it.
ANd could the engine safely handle that without beefing it up?
I tryed this....
2*5660*0.90*2=20376
I still don't understand this "1L=0.0353ft^3".
What does "^" stand for? and you said I need to "make my engine into cubic feet of displacement ", Is that what I sould use for (liters)?
Thanks XstephenX and impreza7,
This really helps a lot
the "^" stands for power. in this case..it woul dbe to the third power.
Old Aug 1, 2003 | 05:04 PM
hotrod's Avatar
details
The TD04-13G is rated at a max flow of 360 CFM at 17 psi, but can hold only about 11 psi, at 7000 rpm on our 2 L engine because the engine wants more flow than it can provide (ie about 460 CFM at 85% VE and a pressure ratio of 2.18 -- 17 psi). It can support almost 24 psi at 3000- 4000 rpm.
http://www.stealth316.com/images/td04-13g-raw.gif
If you put a 16G compressor on the TD04 you'd strangle the engine on exhaust back pressure, it has a 6cm exhaust side, and the stock exhaust side for the 16G is a 7 cm.
360 CFM works out to a crank shaft power out of about 250 hp, if you over spin the turbo you can get up in the neighborhood of 280 but your effeciency is terrible and the air charge will be quite hot -- like over 350 deg F --- can you say "detonation territory" ?
The stock injectors can handle all the air flow out of the stock turbo especially if you run a high density race gas.
Larry
Old Aug 2, 2003 | 11:13 AM
hotrod's Avatar
flow and pressure
A turbocharger is a constant pressure variable flow device. By that I mean you set the output pressure, and it will flow what ever amount of air it takes to hold that pressure (assuming your with in its limits).
The thing that actually determines how much air you flow at a given pressure is the engine displacement, your rpm and the effeciency of the valve heads, intake manifold.
You can put a 1000 CFM rated turbo charger on a 2 liter engine and it will flow essentially the same air flow as a 500 CFM turbo, because the engine is only capable of accepting 460 CFM of flow at 17 psi.
At 3000 - 4000 rpm the engines air flow requirement falls right in the sweet spot of the stock turbos compressor map and the turbo will supply all the air the engine will accept at those rpms and max pressure for the turbo which is about 24 psi boost. (of course you may detonate like crazy at that boost and kill the engine, but the turbo is ready willing and able in that rpm range)
The guys who have run Delta Dash logs have shown that the actual manifold pressure is a lot lower than your boost gauge reads. The gauge just does not read fast enough to show the huge down turn in pressure, because you are only at 7000 rpm for a half a second or so, under max acceleration. Even a VF22 won't hold 17 psi at red line, all though the boost gauge tells you it does.
Yes the weak point in the stock WRX motor is the ability of the valves, heads, cams and intake/exhaust manifold to breath. The engine only flows at 80%+ VE at red line, the RA spec C engine which has much better head design with the AVCS cams flows at about 93% VE at 7000 rpm.
The biggest single problem is the stock cams are relatively mild cams. Once you improve the cams then you need porting and valve work to get higher rpm and breathing at high rpm. The stock intake and exhaust manifolds are fair to good. The stock exhaust works well up into the high 300 hp range, and gives excellent low end torque. Headers are showing their value at high rpm, but typically reduce low end torque enough that many folks go back to stock exhaust manifolds to get back around the town driveability.
Larry
Old Aug 4, 2003 | 01:20 PM
ride5000's Avatar
larry, you kick ***.
-ken
