maf sensor
did you reset the MAF after you installed the intake and boost controller? make sure you unplug the battery for atleast 15 min after you have installed the stuff. then let it idle for about the same amount of time. it might take car of the problem.
also you could just be running really lean. intakes make the car run leaner than it normally would run and i am better the boost controller does too.
also you could have your boost to high. try turning the boost down to around 16. i have heard 17 is tops with out any fuel or computer mods.
Hmmm...Im not sure what it could be then. Does anyone else who has ridden in your car think it feels slower? Do you have a tuner you could take it to? Maybe take it to a dealership. Sorry I cant help out!
Originally posted by WRXKev
Yeah it has been getting warmer but not Unbearable. I have also reset the ecu a million times already. My boost is at 16 under load in 3rd gear so its not too high. I occasionally get the fuel cut but only when its colder out.
I recently got a flashing cel but it still runs the same. I have gotten this one other time but it was when i did my ic hoses and cleaned the TB. I checked for leaks and found none. Now could a maf sensor cause this. I know it did on my 1.8t so why not on these cars.
tscott915
Wanted
Oct 1, 2009 06:46 AM
verc
May 14, 2009 08:10 PM
dan avoN7
Dec 19, 2006 09:46 AM
