low boost problem
Old Aug 15, 2006 | 10:24 PM
03bluWRX's Avatar
Car Info: 03 WRX
low boost problem
ok.. so i reset my ECU hoping that i fixed the problem.. not sure if i actually got the thing to reset though. anyways.
on the stock boost gauge... well.. the picture says it all. is that where i should normally be boosting to or am i still low?
stock 03 wrx
Old Aug 16, 2006 | 10:14 AM
.one lane's Avatar
Car Info: Space Shuttle
Well stock boost is about 0.9 bar. Did you mess around with your vaccum hoses? Is there any leaks?
Old Aug 16, 2006 | 04:08 PM
03bluWRX's Avatar
Car Info: 03 WRX
i havent messed around with anything.
Old Aug 16, 2006 | 07:30 PM
WRX409's Avatar
Car Info: 04 WRX
You could have a vaccum leak.
Old Aug 17, 2006 | 01:49 AM
Jakes02's Avatar
Car Info: 2002 WRX
I assume your pushing the gas pedal to the floor.
Old Aug 17, 2006 | 09:10 AM
WRX>Civic's Avatar
Car Info: '03 PSM Wingless WRX
Question
SOrry but i dont get this. how come you said stock boost can go up to .9? my stock gauge doesn't even go up to .9 it only goes to .15 can someone help me out on understanding this?
Old Aug 17, 2006 | 09:57 AM
.one lane's Avatar
.9 as in .9 bar which is around ~13.5 psi
I don't have the stock boost gauge, so i don't know what measure of unit they use.
Ok, so you didn't mess with anything. Did you at least check what could be the problem? Did you check the lines that lead from that turbo nipple to the "T" to the wastegate, and to the factory boost controller.
Old Aug 17, 2006 | 11:04 PM
Jakes02's Avatar
Car Info: 2002 WRX
Smile
the factory boost gauge is in mpa.
.09 mpa
djwonder925
Apr 21, 2013 12:05 AM
SUMATIC808
Feb 12, 2013 10:37 AM
Shaitiger
Wanted
Apr 6, 2003 09:31 PM
Shaitiger
Apr 2, 2003 12:09 AM
Shaitiger
Mar 30, 2003 11:22 PM
