Low Boost
Old Mar 27, 2004 | 09:33 AM
MO REX's Avatar
Car Info: 02 PSM WRX
If its still under warranty I would take it in before the Accessport is installed. There is a pic of the location your looking for here. http://www.scoobymods.com/forums/sho...?threadid=1564
Good luck
Old Mar 27, 2004 | 12:51 PM
AzN121184's Avatar
Car Info: civic
what gear are you in ?
Old Mar 27, 2004 | 08:21 PM
MO REX's Avatar
I dont think there is a coupler and a restrictor. Im pretty sure there is only a restrictor and a T. The restrictor (coupler) between the boost silinoid and wastegate isnt made of brass its black plastic. there is a pic of it on that link I gave you. Are you sure your looking at the right spot? Someone on the boards thought he was in the right spot and he wasnt. He found a brass coupler but it was on the drivers side of the ic and he should have been on the passenger side of the ic (by the turbo). If you thought your car was fast are sure your boost gauge is working good? I would think your car would be pretty slow with such a low amount of boost.
Good luck.
Old Apr 8, 2004 | 09:07 PM
laurex's Avatar
Car Info: AW '03 wagon
any possibility that a cracked hose from the turbo to bov could cause low boost? I ask b/c my boost gauge flutters, and i only get up to 9-10psi. I checked my i/c hoses and they seem to be fine, and so is the restrictor hose and coupling. Next thing to check would be the uppipe gaskets. any thoughts?
Old Apr 10, 2004 | 01:17 PM
laurex's Avatar
bumpitty bump..anyone?
Old Apr 10, 2004 | 01:27 PM
Is your boost guage signal coming off the line to the bypass valve?
Old Apr 10, 2004 | 04:01 PM
laurex's Avatar
yeah, i slit the hose, and put a brass T fitting to the gauge. cant figure out why im getting low boost. I'm not getting any whistling/screeching sounds coming from the uppipe, so i dont know?
djwonder925
Apr 21, 2013 12:05 AM
Shaitiger
Apr 8, 2003 10:00 PM
Shaitiger
Wanted
Apr 6, 2003 09:31 PM
Shaitiger
Apr 2, 2003 12:09 AM
Shaitiger
Mar 30, 2003 11:22 PM
