just installed vf39 on a 02 wrx CEL
Old Dec 7, 2007 | 08:59 AM
Bushflyr's Avatar
Car Info: Bugeye Wagon - VF39'd
Try pulling tyhe code even if the CEL is off, it may still be in there. A pop when you let off the gas is sometimes normal, it's probably just afterfire. If you rev it slowly in neutral can you hit redline? If you rev it fast the needle may be lagging and you're hitting the rev limiter before the needle catches up.
Old Dec 7, 2007 | 01:11 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
alirght..so i went to paul but he went to a Funeral so no success there..maybe next week..hope everything is alright..anyways..if i rev it..it stops at 6k rpm..as i was drving back from paul's shop the speed needle is like floating...like if i was going 70 mph the needle would be boucing around at that speed like 67 or 72..not sure what is up..and also got a CEL finally..which is showing 1,2,3,4 cyclinder's misfiring..
Old Dec 7, 2007 | 10:41 PM
Bushflyr's Avatar
Ok, well I'm out of ideas. The bouncing speedo would indicate to me that you have an electrical problem somewhere. Maybe a bad ground? All cyls misfiring could also be an electrical issue. Other than that, I'm fresh out of ideas. Try the shop again if you can't find anything loose. Post up here what it was when you get it solved. I'm really curious.
Old Dec 8, 2007 | 02:05 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
hey its all good..thanks...i really appreciate your guy's help..i'll inform you guys asap. some people are telling me that its time to get a protune. I agree..but its just my budget isn't there haha..otherwise i would. but i dunno..it doesn't bother me too much except for the fact that the cluster is all acting up because an electrical issue.. but other than that im glade its running smooth..and not running at all..i'll keep you guys posted..because..the next day to visit him would be next week..monday or tues..if you guys have anything for me limmie know...thanx again.
Old Dec 8, 2007 | 08:45 AM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
I'm here today...Saturn's Day the 8th.
Old Dec 8, 2007 | 09:03 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
crap..i have to work... boo...maybe early next week..
Old Dec 11, 2007 | 08:29 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
so it off to DB tunning on friday. hopefully we'll figure this out and finally. step away from this situation.
Old Dec 17, 2007 | 09:11 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
ok so update: Took the car to DB tuned and paul helped me out by finding hecka vaccum leaks. So i just gotta got those fixed and then im due for a clutch replacement soon, and also to get a 60 k maintence done..
Old Dec 20, 2007 | 06:36 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
PROBLEM FIXED...spark plugs changed They gotta be one step lower spark Plugs.... vacuum leaks..at DB tuned we used a machine to figure where all the leaks are coming from...replaced the areas ..and found a loose ground...and just tightened it...anyways thanks guys. for all your help.
Old Jan 13, 2008 | 03:04 PM
gi2005's Avatar
Car Info: 04 wrx
when the shop fu**ed me up the *** by not installing my pink injectors on my 2002, i was running the cobb vf39map on stock injectors and cel came on because the car was running too lean but car never stalled out
Old Jan 13, 2008 | 03:46 PM
VRT MBasile's Avatar
I think he got the problem fixed
Old Jan 13, 2008 | 09:19 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
hah yea hommie problem fixed....
Old Jan 14, 2008 | 02:43 AM
AzN121184's Avatar
Car Info: civic
what shop was this?
cwc16
Sep 7, 2012 12:00 PM
WRBLUEballs
Mar 3, 2011 07:37 PM
mistaanime
14
Aug 29, 2008 02:54 PM
Jake
Feb 23, 2007 01:25 PM
Winding Master
Feb 1, 2006 11:22 PM
