Intake silencer removal
Old Nov 24, 2002 | 11:57 AM
Dick Fitzwell's Avatar
PN46059FA000 couple bucks IIRC
Old Nov 24, 2002 | 02:59 PM
Choku Dori's Avatar
Car Info: Corvette Z51
Originally posted by Arcanum
IMHO, Shiv seems to be a good guy. I have no personal experience with him, but how could you prove a 1HP loss? I've seen dyno runs of the same car back to back show differences of 5 HP.
/\rcanum
Bad way to put it... I meant a nominal horsepower loss as opposed to literally 1hp. Sorry!
Old Nov 24, 2002 | 06:07 PM
ScoobyBoy's Avatar
the firewall thing that nevz was talking about works. i used that to route my boost line to the TT, and after that i heard the turbo much louder. i left the plug in, but i taped it on, so it wouldnt fall out. if you do decide to take it out watch out for it, dont let it fall out, itll be a ***** to fish it out.
Old Nov 25, 2002 | 04:51 AM
thejean's Avatar
Car Info: 02 WRB WRX
Intake Silencer Testing
Myself and another member did some Delta Dash testing of the intake silencer mod. We tested three scenarios:
1. Stock intake
2. Silencer removed
3. Silencer removed and dryer hose to connect airbox to scoop
All testing was conducted on the same day on an otherwise stock WRX. Results shown are for three WOT runs up to 4th gear. #3 run was cut off due to police presence.
In the attached pictures/files I will show three charts:
MAF vs MPH
MAF vs RPM
MAF vs Time
JC
Old Nov 25, 2002 | 04:54 AM
thejean's Avatar
MAF vs MPH
This chart clearly shows that MAF is highest for all MPH ranges with the stock intake. This indicates that a "ram air" effect is occurring at higher vehicle speeds due to the ram air effect in the front of the car. Note that this is good.
Caution - this chart does not take into account RPM yet and thus, these results seem to indicate an obvious advantage for the stock setup at this point...
thejean's Avatar
MAF vs RPM
This chart clearly shows that MAF is better for the modded intake silencer but starts to fall behind in the upper revs. Nontheless, its not so much worse in the upper RPM ranges that it offsets the obvious gains obtained in the lower RPM ranges.
Also note the significant amount of scattering of the data in the stock setup. This shows that the intake silencer mod provides much smoother airflow due to decreases in turbulence in the intake.
Old Nov 25, 2002 | 04:56 AM
thejean's Avatar
MAF vs Time
As can be seen by this chart, the silencer seems to hinder spool-up time and the MAF increases more rapidly for modded silencer options.
Old Nov 25, 2002 | 04:59 AM
thejean's Avatar
Conclusions
So, as you can see from the attached graphs, the stock setup seems to be better than the others in the upper RPM's and the silencer mod results in low end gains. I also did a statistical analysis (multiple linear regression) using MAF, MPH, RPM and IAT and the MAF reading seems to correlate well with MPH and RPM, but not IAT.
So, based on what I see in this chart, there is either some "ram air" effects from the stock intake or it is accessing colder air at high RPM/MPH (most likely the former). Note that the MAF takes into account air velocity and temperature to be able to calculate the "mass of air" entering the engine. Of course, the more air you can get in, the more power you are going to make.
My experience with the silencer mod (I currently have the hacked version) was that it provided increased smoothness and low-end gains. These charts support my hypotheses based on the 'ol butt dyno.
JC
Old Nov 25, 2002 | 05:14 AM
Thumbs up
bravo! this monday's learning points goes to thejean....thx for the footwork
