Installing STI innercooler in reg. WRX
Old Apr 7, 2004 | 11:46 AM
VRWRX's Avatar
Car Info: 2005 CGM WRX Wagon
Yes, an STi intercooler will work. Try to search and you should find some good info on the swap.
Old Apr 7, 2004 | 12:12 PM
ScoobyBoy's Avatar
not very hard at all...just remember the steps you took to remove the stock intercooler and just do the same in reverse order.
Old Apr 7, 2004 | 12:35 PM
KDamericano's Avatar
Car Info: 2003 WRX
The install won't take long at all. But just so you know, you probably won't notice much of a performance difference because you still have the stock turbo pushing the same amount of boost. If you threw an aftermartet turbo in there, then you'd reap all the benefits.
Old Apr 7, 2004 | 01:20 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
These guys haven't done the reading they're telling you to do... This is what I learned when thinking about getting one of these.
The USDM STi IC requires that you use the USDM STi brackets (or modify yours) to properly mount it.
The JDM STi IC (which is also bigger), bolts in perfectly. Go figure.
Old Apr 7, 2004 | 01:21 PM
If you're planning to mod further...it's not a waste. But in terms of bang for the buck, you won't really feel much on the stock turbo with stock boost. And you definitely won't feel anything from IC hoses.
Old Apr 7, 2004 | 01:37 PM
VRWRX's Avatar
Originally posted by leplat
Alright so bang for buck would changing the uppipe make any different...
Absolutely. An uppipe is probably THE best bang for the buck mod you can make. Your butt dyno will thank you!
Old Apr 7, 2004 | 04:29 PM
orwrx's Avatar
Car Info: WRC replica
I also had found a USDM STI with only 500 miles on it. I found it from other member in the other forum and he was asking for $320 shipped. Since I noticed that I couldn't drop it it directly. I let it go. If you really want the intercooler, go with JDM.:banana:
Old Apr 8, 2004 | 06:10 AM
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
hope u win that auction!
if u keep stock TMIC just paint the red STi on it. . . it would be the same effect! if u keep stock turbo. . .
