I Got Gas
Old Nov 17, 2003 | 01:48 PM
SuboobaruWRSEX's Avatar
Car Info: Viper ACR & H1
Exclamation I Got Gas
My car is running too rich. My car is white and has a brown rear bumper. It has a stock fuel system, Injen intake, Gruppe-S up pipe, HKS down, Apexi N1 cat back, 9.5 lb flywheel, and ACT clutch. Took it into shop and read error code for too rich. I was thinkin about putting on a adjustable fuel pressure regulator and turning it down a lil. Any ideas?
Nick
Old Nov 17, 2003 | 02:51 PM
MonkeyAB's Avatar
Car Info: 2001 Impreza 2.5RS(Ti)
I'm no expert but try ditching the intake. From what I've read on the board those can make your car run rich. My $.02.
Old Nov 17, 2003 | 06:05 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
put your stock airbox back in and your problems will be solved
Old Nov 18, 2003 | 11:32 PM
raazin's Avatar
Car Info: 2002 wrx wagon black
good luck
Old Nov 19, 2003 | 04:45 AM
andyhidley's Avatar
Car Info: 2002 WRX
Scott@S-Squared I have the stock intake. And with the airbox removed it does run richer than with it installed.. I think you have it figured out!
Old Nov 19, 2003 | 12:17 PM
andyhidley's Avatar
Car Info: 2002 WRX
Your correct , kinda, about putting on a higher flowing intake. This will deliver more air. The problem is that the MAF sensor gets fooled and sends an inaccurate signal to the ECU which in turn richenes the mixture
Old Nov 19, 2003 | 01:34 PM
Is there any other way to trick the MAF into running a little leaner? Or would it just be easier to use an adjustable fuel pressure regulator?
Nick
Old Nov 19, 2003 | 02:49 PM
andyhidley's Avatar
Car Info: 2002 WRX
some kind of engine management system, i.e. utec. adjustable pressure is askin for trouble...... to do it right you also need EGT + air fuel gauges
Old Nov 19, 2003 | 06:50 PM
Thanks. Well Christmas is around the corner. Maybe Santa will buy me a Turbo XS UTEC. If he dosnt there will be hell to pay.
Nick
Old Nov 20, 2003 | 06:41 PM
alster's Avatar
Increase your boost and you will run leaner.
gil
Jul 27, 2005 01:41 PM
kidatari
Sep 9, 2004 12:22 AM
brucelee
Jun 5, 2004 09:58 AM
nachomc
Jun 1, 2004 11:20 AM
trebsrex
Oct 5, 2003 12:18 PM
