how wide of a wheel and tire wrx can have
Old Nov 25, 2003 | 11:37 AM
namitherussian's Avatar
Car Info: Black WRX
i looking to get 18X8 with a 235 tire, is that too big for WRX?
what are the pros and cons of a wide wheel and tire?
Old Nov 25, 2003 | 10:06 PM
Daredevil's Avatar
you'll be slower
but you'll hug the ground real well in the twisties
and its a lot more for your axle/tranny all that shiza to turn
im just guessing at this
Old Nov 25, 2003 | 10:27 PM
dropkick_muppet's Avatar
Car Info: '03 PSM Sedan
some guys are running stuff larger than that, but most of them are relatively hardcore auto-x'ers going for really wide rubber. i've read about stuff from 17x8.5 running 245s, to 17x9.5 running 255s.
Old Nov 26, 2003 | 05:17 AM
Car Info: Black WRX
hmm really tough choice to make, i know running 18x8 the car will grip better the only thing i am concerned about are the pot holes and damage to the wheel i really dont have money to throw around and buy new one if gets damaged, overall what do u guys think is it better to go with 17's?
Old Nov 26, 2003 | 05:18 AM
Car Info: Black WRX
wow those tires on cobb car are huge
Old Nov 27, 2003 | 09:18 PM
mmboost's Avatar
There's more things that go into allowable wheel size than section width and wheel diameter and width. You need to consdier wheel offset, suspension setup (particularly travel, ride height and camber).
I'd also recommend against 18s on city streets. 245/45 is substantially different over all diameter than stock.
I run 235/45 on 17x8. Feels great. My drop is a bit too much, more than the Tein specs or my High-Techs, almost 50mm
jason
Old Nov 28, 2003 | 08:23 AM
international B's Avatar
Chewwwwy
if your car is too low you will rub when you load it hard. i would reccomend 17's due to the fact that the tires are cheaper!
Old Nov 29, 2003 | 05:43 AM
Car Info: Black WRX
Thank for you answers, yeah i think i will prolly go with 17x8 and get a 235 tires
Old Nov 29, 2003 | 10:47 AM
iLoqin's Avatar
Car Info: Nadda
Can 235's fit on 17x7.5? Or do you need to have it at 8's ?
Old Nov 29, 2003 | 11:16 AM
Car Info: Black WRX
you should be able too i think
