How to make an external WG run spring pressure?
Old Oct 21, 2003 | 11:32 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
How do I connect the vaccum lines to the gate?
Of course, there are 2 connectors, one on top and one on the bottom.
Old Oct 22, 2003 | 12:39 AM
Speed Element's Avatar
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
Are you asking how to connect a external wastegate mate? If so hit us up at the shop when you can.
** Just read your post again, never ran spring pressure other than using a boost controller on wastegate set to spring. Try connecting to two lines perhaps??**
Mike
(510) 487-4447
www.mpjperformance.com
www.gb-motorsports.com
Old Oct 22, 2003 | 08:52 AM
Mister 2's Avatar
Don't know what kind of 'gate you got but if I recall correctly the spring pushes the valve down which closes the gate. To run just spring pressure you want to connect just the bottom vacuum line where pressure (aka boost) will oppose the spring.
edit: I just checked some other references and there are some differences in wastegate design. Just figure out which way the spring goes to keep the wastegate closed and then you can figure out what port to use.
Old Oct 22, 2003 | 10:13 AM
Jgrahn555's Avatar
Sarcastic Jackass
Car Info: i drive a beater
which wastegate are you running?
Old Oct 22, 2003 | 11:30 AM
Imprezer's Avatar
Admin v2.0
Greddy Type R.
JDMGC8
Aug 12, 2014 04:03 PM
suby_dude
Feb 12, 2008 01:28 PM
OuTkAsT WrX
May 10, 2005 12:24 AM
mazspeedpro
Apr 23, 2003 09:53 AM
BoOm
Feb 16, 2003 10:08 PM
