How can you check if Turbo is spooling
what rpm do you feel the turbo spool up? mostly likely though, you're just used to it. Took me a week to get used to my car. I guess i was all excited when i first got the car and worshipped its power, and now i'm taking its performance for granted
Do you have a boost gauge installed in your car?
Have you added anything to the engine?
You could also try an ECU reset to see if your original performance comes back. Disconnect the negative battery terminal, sit in the car and press the brake pedal and release a few times, then re-connect the negative battery cable. You may lose your radio presets and trip odometer reading (but not the main odometer).
impreza-tux-121
May 31, 2007 09:48 AM
subieboy
Feb 18, 2007 06:13 PM
wrecks43
Feb 1, 2007 10:05 AM
Hurucan
Aug 28, 2006 12:15 AM
Silverbullet04
13
Jan 15, 2004 06:45 PM
